Question about Mackie SWA1801 Subwoofer
How to open SWA1801Z
I need to replace the speaker on a SWA1801Z. Does anyone know how to open the enclosure?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
Please follow the guide given in the link.. there is a chapter on woofer replacement..
http://www.mackie.com/pdf/repair/SWA1801z%20repair%20guide.pdf
--please give your comments..
have a good day
sree
Posted on Jul 01, 2008
How do I open the enclosure to replace the mid range speaker?
Some sealed enclosure are accessible only from the front. Removing the speaker(s) is the only way in.
Nov 09, 2015 | Audio Players & Recorders
Does anyone know the actual airspace requirements for sealed and ported enclosures on these speakers? Please no idiots building cube boxes need to respond!
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 11 inches x 11 inches x 11 inches. Hope this helps
Feb 17, 2011 | Autotek MX-1222 Car Subwoofer
I have a 2004 acura TL. I need to replace the sub in the rear. It sits above the back seats and I can't figure out how to get to it. Anyone know how?
There should be a molded enclosure in the trunk, underneath where the sub is. It is either screwed in, or held in with body button clips.
Sha'ul Dag
May 04, 2009 | Car Audio & Video
DAV-IS10 Speaker Blown
OK, Subwoofer model number is SA-WSIS10and you need middle speaker mounted on top under following part number..
1-826-658-11 LOUDSPEAKER (12 cm) (MIDDLE)
Available in Part Store.
Mar 23, 2009 | Sony DAV-IS10 System
JBL spot series speaker not working.
I know this is old but just incase anyone has the same problem. Its proabably the connection from back panel to the internal amp (Inside the sub enclosure). The ribbon cable has the + for the left speaker right at the edge with quite a bit of tension. Over time and with the vibrations from the sub this will bend/pull out slightly and needs to be pushed back on and some hot glue put around the connection to hold it in place.
Thats how I fixed mine anyway.
Jul 12, 2008 | JBL Spyro Computer Speakers
Subwoofer replacing,
Hi , try visit : www.Shopping .com
May 06, 2008 | Car Audio & Video
Karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Apr 15, 2007 | Vocopro PV420 Main / Stereo Speaker
Mackie SWA1801 Subwoofer Logo
498 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
