Question about Intertherm Heating & Cooling
I have an intertherm center heater. I just purchsed the new house and it finally became summer. I tried to turn the fan on only as I am used to in other homes. However, the fan does not come on. I looked in the inside of the heater and see that a gray wire is not hooked up, which may be the fan relay??? Any help appreciated.
  • 12 more comments
  • mceach Jul 01, 2008
    There are still two wires left from Therostat not attached - blue and yellow AND a gray wire from the heater unit itself not attached???????????
    The heater works fine with the fan when in heat mode and turning up the thermostate but it won't work in the FAN MODE ONLY
    My question is should the GREY wire from the heater be attached to one of the wires from the thermostat? Gray wire not connected to anything in the heater?????
    Heater unit is Intertherm E3EB-015H and therostat is Honeywell...The thermostate is for both heat and air cond but I only have a heater
    You can go tohttp://www.nordyne.com/Literature/710386... to see the wiring diagram for the unit
    What!
    Intertherm Model 904131 E3EB-015H
    In the therostat all 4 wires are screwed into slots....the red in Rh, Blu in Rc, white in W, Yellow in Y, and Green in G....HOWEVER, in the furnace the blue and yellow are not connected to anything....???
    I connected the yellow and green therostat wires together on the furnace side to the green heater wire but still not fan only....
    I have the wiring guide http://www.nordyne.com/Literature/710386
    That link didn't help - it doesn't even list furnaces.
    the link did NOT HELP - no heater problem there only air conditioning and I don't have air
    The diagram above is on the furnace...so the green wire is the fan for the heat, I would connect whichever wire (Yellow or blue) that runs the air portion and also hook that up to the green, then when I put it in air condition mode it should run the fan????
  • mceach Jul 02, 2008
    I fixed the problem myself after going to Honeywell install manual. I had to jump the two wires in the therostate box. Thx for all your attempts
  • 2,071 Answers
Site for wiring diagram;..
http://www.xpedio.carrier.com/ide/groups/public/documents/techlit/
ag-maba-03.pdf
Posted on Jul 02, 2008
    Champion:
  • 254 Answers
Hello mceach please bear with me on this. If you could please give me a model number on the thermostat I am curious if it has a bypass option which would strike the g terminal running the fan. I am also looking in my nordyne literature to confirm the addressing of the wiring in the fan relay. Just as soon as I have more info I will comment again, but the thermostat model number sure would be handy.
    Genius:
  • 2,028 Answers
Is the wiring diagram you have for te furnace or thermostat? If you have the diagram for the furnace, locate the circuit that controls the fan, then try wiring the air side of the thermostat to that circuit. This should allow you to control the fan only with the air settings on the thermostat.
Posted on Jul 01, 2008
  • Ryan Rogers
    Ryan Rogers Jul 02, 2008
    Glad you got it fixed. Sorry we weren't much help, maybe next time.
    Genius:
  • 1,665 Answers
As you possibly dont have a wiring diagram or service manual, to avoid a sort circuit, better take it to an authorized service to check its wiring internal connections.
    Genius:
  • 2,035 Answers
  • 828 Answers
Http://www.nordyne.com/Literature/7103860.pdf
According to the wiring diagram and standard wire routing a wire should go from the "G" terminal on the thermostat and "G" terminal ( or green pig tail at the heater.)
  • 2 more comments
  • James Helmer
    James Helmer Jul 01, 2008
    Grey wire at the heater you seen is an extra speed wire which is not used.
  • James Helmer
    At your thermostat; The Rh is for power to the thermostat.
    The W is for the heating control.
    The Y terminal is for the air conditioning unit which you do not have.
    The G terminal is for the fan relay which turns on the fan from the thermostat.
    On your thermostat there would normally be a jumper between Rh & Rc because you have but one transformer supplying the power. The G terminal at the thermostat must be connected to the Green pig tail or G terminal at the furnace.
  • James Helmer
    James Helmer Jul 02, 2008
    I can see clearly that there is a bad communication problem here.
    There seems to be so very many solutions to a simple problem that only cause confusion to the person on the other end who is trying to accomplish the task.
    Yellow and blue wires are only for A/C application. If they have been connected together in any manor disconnect them from each other.
    Connect the G thermostat terminal wire to the green pig tail wire on the IFR wire as shown on the diagram. That should take care of your problem. If you are in doubt in any way call in an A/C or heating tech to solve your problem.
  • James Helmer
    James Helmer Jul 07, 2008
    I'm willing to bet this guy jumpered Rc & Rh at the thermostat as was stated in my second post.
    Master:
  • 497 Answers
Model No..Plz
  • Yaz  S
    Yaz S Jul 01, 2008
  • Yaz  S
    Yaz S Jul 01, 2008
    i know that the link above is E2 series, but u cud compare for similarities if possible.
    i really hope that this helps
    All the best
    Thank you for using Fixya.
    Master:
  • 638 Answers
Have your problem solved you had rated some1 as best solution.reply
  • 4,472 Answers
It could be a bad switch/control circuit and that is why it won't work in that mode only.
Thanks,
lee
  • 3 more comments
  • Lee A.
    Lee A. Jul 01, 2008
    Have you tested it with a multimeter to see if/when juice is flowing out of it? What is the exact model of the unit?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 01, 2008
    Outdoor reset sensor is what i believe the gray wire is. It is used for adjusting the temperature inside the house compared to outside. I don't believe this is what you are looking for.Thanks,
    Lee
  • Lee A.
    Lee A. Jul 01, 2008
    You purchase the sensor to hook up with the wire seperately and that is why it is most likely not connected to anything.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 01, 2008
    Ok, then that is definitely what the gray wire is for then. So you have never witnessed the fan working then in only fan mode? Do you know if the unit is under warranty at all?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 02, 2008
    Well i believe a few people basically suggested that same thing exactly to look at your manual and to wire it properly. I think you should have found someones solution helpful and accept it as they gave you great information and avenues to search.
    thanks,
    Lee
    Sergeant:
    Champion:
  • 230 Answers
The problem is because of the loose connections i think so ,if you have warranty for your device then go for it,because repairing by own may void warranty.And also without seeing ,we cant repair by trial and error method ,so better go to serivce center and service it
Where is the summer/winter switch located on Dayton Fuel Trimmer furnace model 3E438A.?
The typical 'summer/winter' switch is an added switch associated with OLD heating systems back in the 50's and 60's before central air conditioning became common in homes. I doubt that your new furnace had one installed because you can accomplish the same thing by switching the fan on at the thermostat sub-base. That is, of course, providing you have a subbase with 'fan-on-auto' on it.
Jan 07, 2015 | Dayton Heating & Cooling
Installed new wall heater and thermostat and pilot is on but heater will not come on?
What about thermostat wire? What ya got 2 wires right? Touch them together she supposed to ignite the flames then after a few minutes the fan kicks in on fan models. You got the knob on the gas valve turned to the "ON" position?
Nov 07, 2011 | Williams (5009622) Ceramic Gas Wall...
No AC from older Intertherm split system
It sounds like you are low on refridgerant. Double check to make sure both fans and the compressor are running. If so then you have a refridgerant problem.
Aug 29, 2009 | Heating & Cooling
Get a screeching sound from unit when heater is on.
Chances are it is the outdoor fan motor. Does it squal when you run the A/C? If not it could be the reversing valve solonoid.
Jan 16, 2009 | Intertherm P3RA-048K Air Conditioner
Furnace is not turning on
Sounds like you have a bad fan limit. they will sometimes kick on in the summer when the temp gets high enough. now it sounds like it is not working at all. it is usually mounted with a metal square cover over it removing the cover would expose the dial this it what turns as the furnace heats up and kicks on the fan . turning it by hand will check to see if fan will kick on(turn a lttle clockwise)
Jan 10, 2009 | Heating & Cooling
Not heating
1st you said the fan runs..but partial info so best guess it fan limit contor bad.
Jan 07, 2009 | Intertherm P3RA-048K Air Conditioner
Fan Only Won't Work
I jumped the rc and rh wires in the therostat box and now have fan only when selected.
Jul 01, 2008 | Heating & Cooling
Laser 30
EE 8 means there is a problem with the blower fan. It could be faulty or it could just be stuck. Did you leave the heater off for a long time? Like all summer? If so then it is probably just stuck. You can easily check if it is just stuck by following these steps: turn the heater off. grab a flashlight and a screwdriver and kneel down next to the left side of the heater as you are facing it. Look behind the heater near the bottom and you will see a flexible gray rubber L-shaped hose that is attached to the blower fan housing. This is the fresh air inlet for the heater. Next, loosen the hose clamp screw on the gray rubber hose elbow that attaches to the back of the heater. You may need a stubby screwdriver depending on which way the clamp is facing. Pull off the rubber elbow and stick your finger into the hole in the blower housing. You should feel the fins and hub of the round fan. This should turn freely. If it doesn't, then you can try to spin it with your finger a few times as you turn the heater back on. Do this carefully, you don't want to bend or warp the fan. If it begins to spin freely, you should hear it and there will be some slight suction INTO the housing. It may work normally now, although it will likely make more noise than it used to, due to the motor bearings being inactive for a while. Replace the rubber hose and clamp, and run the heater on high for a while by adjusting the SET temp up. It is important with the Laser 30 to run it frequently, even at a low setting in summer to keep this from happening. If you turn it off and let it sit for even a few days or weeks at a time, this will probably happen again.
If this does not fix your problem, email me at toyofreehelp@yahoo.com
Nov 10, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
365 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
