When i change the temperature to make it hotter, the screen blinks then goes back to being 30 degrees colder. Is my heater ignoring my request because it never reaches the temperature i want it to. it sticks to 55 or 60 degrees. i have model 755320 the lasko ceramic air heater.
  • 2,133 Answers
First you have to understand in thermostat there are Fahrenheit & Centigrade degree. If Centigrade between 16 to 30 and if it is Fahrenheit 60 to 86.
If you press the symbol ther> and > (or) ther- and ther+ at a time degree will change.
Now you set your temp +10 degree from your room temp and also keep "heat" mode.
Posted on Dec 14, 2010
SOURCE:
04 gran prix no heat. clogged heater core? how do i unplug it?
with the engine at operating temp touch the heaters hoses one at a time. if they are the same temp or one is colder then the core is plugged, if one is hotter then the other then the core is not plugged. one hose should be at least a little hotter then the other. when was the last time you changed the thermostat they get weak and open too soon not allowing the engine to get to the proper temperature.
Oct 11, 2014 | Cars & Trucks
How do I just the water heater to make the water hotter
To make the water hotter, u may constrict the water flow that goes through the tap, shower etc. With the water flows slowly, the heater has more time to heat the water in it and then the water will be hotter although it won't be boiling hot(100 degrees Celcius) because the water heater is not designated to heat water up to that temperature
Apr 09, 2013 | Water Heaters
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Temperature knobs won't change temperature Chevy Tahoe
You likely have a HVAC control head failure. The rear heater problem is likely a door actuator, the rear wiper is likely a open wire in the door jamb in the top. The gauges are likely a cluster failure.
Oct 17, 2012 | Chevrolet Tahoe Cars & Trucks
My Whirlpool wall-mounted air conditioner is not allowing me to lower the degree temperature. I only had it installed several months ago, and it worked great and I was able to continuously keep it at the...
Try un plugging it for a while like a munite or 2 and plug it back in .. befor eyou plug it back in though remove the batteries from the remote as well I MIGHT rest it .. I'll keep my finger crossed for ya
Jul 19, 2011 | Heating & Cooling
Recently purchassed system from you plumber installed it and we asked specifically not to set it on child settings.....we have not had one HOT shower since. how do we go about resetting the hot water...
These Tankless water heaters attempt to heat water as it quickly travels through a short series of heated copper pipes. A high volume of water at an accelerated speed has little time to heat up as it passes through its heating source. You can turn up the temperature (which you undoubtably tried) and turn the water volume all the way down. These settings will produce the hottest temperature capable of the unit - given the entry temperature of your water source.
Most underground water enters at app 52 degrees - and becomes even colder due to ambient temperatures. Difficult to raise this temperature 60-70 degrees in a few seconds of heating.
I've routed a series of copper pipes adjesent to the home heating system in an attempt to pre-heat incomming water. It's only a few degrees warmer, but results a 20- 30 degree hotter delivery.
I have installed some top end units that simply delivers Hot water without compermise.
Mar 01, 2011 | Bosch & Tankless LP Hot Water Heater
Lasko 5141 - I set the temp to hold @ 68 degrees at night but it seems to ignore the setting and gets into the high 70's. This is with the rotation switch on if that makes a difference. Any Help ? Thanks
Remember it is always colder at the floor level, the heater is pretty close to temp when it is above 40 degrees outside, but as the temperature gets colder outside so does the temperature at the floor level in your house because heat rises.
I use my house furnace thermostat mounted half way up the wall as a guide, When the temp outside is in the teens, I have seen as much difference between the floor temp on the heater and the wall to be 4-6 degrees different. So this means as the tempurature outside drops you need to regulate the thermostat on the heater downward to compensate for the colder floor temperatures.
Jan 10, 2011 | Lasko 5141 Ceramic Electric Heater
KENMORE DISHWASHER CLEAN LIGHT BLINKS SEVEN TIMES M#665.17029403
The thermistor beneath the accumulator inside the sump detects the water temperature as it begins the first 8 minutes of the main wash cycle. During this time, the controller expects the thermistor to detect the 2-4 degrees rise in the water temperature when the first 8 minutes is completed. If the expected temperature rise is not met, the controller will not be satisfied. It will shut the dishwasher down and blink the clean light 7 times. Press the heated dry then normal wash buttons in the same sequence two times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button. It will clear the fault and makes the dishwasher run normal but the fault will appear again if you have problem in either of the following:
  1. Heater and its circuitry
  2. Water filling
  3. Pumping motor
If the heater is not working, the water temperature will not rise then controller will shutdown the machine.
If there's no water entering the machine, no water will be heated and there's no way the controller through the thermistor can detect any rise in temperature.
If the pumping motor is not working, the water cannot circulate over the heater and be heated. Again, the controller will not be satisfied.
You can bypass this fault detection feature by filling the machine either with extremely cold or extremely hot water. Water colder than 62 or hotter than 160 degrees Fahrenheit will make the controller not to check for a temperature rise but rather continue on the next cycle.
Please let me know if the problem still bother you.
Dec 03, 2009 | Refrigerators
Clean lite keeps flashing will not start whenstart
The thermistor beneath the accumulator inside the sump detects the water temperature as it begins the first 8 minutes of the main wash cycle. During this time, the controller expects the thermistor to detect the 2-4 degrees rise in the water temperature when the first 8 minutes is completed. If the expected temperature rise is not met, the controller will not be satisfied. It will shut the dishwasher down and blink the clean light 7 times. Press the heated dry then normal wash buttons in the same sequence two times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button. It will clear the fault and makes the dishwasher normal but will appear again if you have problem in either of the following:
  2. Water filling
  3. Pumping motor
You can bypass this fault detection feature by filling the machine with either extremely cold or extremely hot water. Water colder than 62 or hotter than 160 degrees Fahrenheit will make the controller not to check for a temperature rise but rather continue on the next cycle.
Dec 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Default temperature settings
if it is anything like a monitor - look on the right side bottom for a slider - reset temperature adjust. just move the slider to a lower temperature. if you have a power outage, the display starts to flash 88:88
Dec 15, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
234 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
