FixYa.com
Tags:
Garmin Nuvi  660 GPS Receiver
My Garmin Nuvi 350 ON/OFF (by 2 users)
posted by RAYMCIVER on Jul 01, 2008
My Garmin Nuvi 350 ON/OFF button does not work. I cannot turn it on and cannot turn off once it is on. Is it a problem with system set up or broken button?
Thanks,
Cheonil Kim in Boston
MY NUVI 650 ON/OFFBUTTON WILL ONLY WORK WHEN IT IS CONNECTED TO A POWER SOURCE.I OWNNED A 360 AND IT TURNED OFF/ON WITHOUT BEING PLUGGED IN.ONLY THE RESET BUTTON CAN TURN IT OFF WHEN NOT PLUGGRD IN. THIS IS VERY ANNOYING.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by alandkathi, posted on Jul 02, 2008
Can anyone describe how to open a nuvi 350? The problem with the on off switch is with the switch's solder connections and I would like to perform the repair. How do I open the case?
Best Solution
FixYa! (100)
sharcnet
Rank:Guru Guru
Rating: 91%, 335 votes
This is a common problem with the Nuvi series. The on/off switch is a surface mount switch that is mounted vertically off of the main PC board.
The problem is, that there is no support behind the switch, so when you press down the button, the solder leads of the switch are stressed and eventually break off the main PC board. This is a design flaw and could have been easily prevented by wedging a small piece of plastic between the rear of the switch and the SD card housing to give the switch support.
Also, the solder pads for the mechanical connections of the switch could have been made bigger, allowing for more surface area and more solder application.
I have repaired many of these before and I'll be posting a step-by-step procedure on how to fix this and prevent it from happening again.
I must point out however, that in order to make this repair, you will need to have skills in dissassembly and soldering. Also, you will need a very small soldering iron - one with a very small pointed tip.
Also, please only attempt to work on your unit if it is out of warranty.
If you would like for me to repair your GPS, please email me at KS3R at sharc dot net. I can also provide you with a step-by-step procedure via email on how to take apart the unit.
- Jim
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these GPS Devices problems?
660 will not locate satellites
660 will not locate satellites.... Answer This...
screen appears...
My Nuvi 660 is about a year... Answer This...
i require a download of
i require a download of bridge... Answer This...
finding small towns
Many of the streets in small... Answer This...
"map info" grayed out
Map info grayed out. Gtet... Answer This...
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
