Question about Frigidaire GLTF1670A Front Load Washer
Makes a noise like there are rocks or coins when it spins
Makes a noise like there are rocks or coins when the washer spins
    Problem Solver:
  • 4 Answers
If it is thumping... you have a broken spider on the inner stainless steel drum. Major defect with this machine. You'll need to call to get a new washer tub assembly... comes complete with inner stainless steel drum and outer plastic drum already assembled and ready to install. Good luck.!
Posted on Aug 05, 2008
Making a terrible noise when water is going in on spin cycle.Ok when filling .Please help
You hav debris in the drain pump. It's mostly rocks, pieces of glass or coins. You will have to remove them.
Jan 03, 2016 | Washing Machines
Making terrible noise when water is running on spray and spin .Ok when filling first off and on deep rince.Please help
You hav debris in the pump, such as rocks, glass oof coins. Please remove them from the pump.
Rocks while in spin cycle
Hi, I believe the cause of your washing machine's "rocking" problem is the result of the machine not being properly balanced (on all four legs). Let me explain. On the bottom of your washer and dryer, are four "adjustable" legs. These legs screw up or screw down. If you adjust these four legs so that the washer is perfectly square with your floor, your rocking problem will go away. This should do the trick. Good Luck!
Jan 10, 2011 | GE WSXH208A Front Load Washer
Washer is very loud during spin cycle. The machine is well balanced and does not rock
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Nov 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
Makes Noise When Draining on Spin
could be coin in pump..Check this
Apr 08, 2010 | LG WM2487H Front Load Washer
My washer make noise to loud when It spin mode. how to fix it
what does the noise sound like is it a high pitch squeeling noise or grinding. need more info
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Noise under drum
1) Round the door seal - happens all the time on all sorts of machines. 2) Wait for it to find its way into the hose going down to the drain pump, then dig it out from there. (You might want to check that there isn't already something stuck in the hose preventing your mystery object making this most natural of journeys). A.
Apr 08, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
224 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
