Question about Lexmark X1270 All-In-One InkJet Printer
Same problem What if the power light blinks continuously - even after removing power cord, removing both printer cartridges, and then plugging it back in? Thanks
No start up cd
Posted on Aug 25, 2008
Blinking light
Try to Reinstall the cartridge , if the blinking continue , try to remove ink then unplug the power cord and reconnecting power cord with ink then see blinking for ink , then install the cartridges , if hope this help
Mohamed Hejazi
Afaqnama - Tripoli, Libya
IPG@hplibya.com
Mar 20, 2013 | HP DeskJet 5150 InkJet Printer
Ink indicator keeps on blinking even with new ink cartridge.
The blinking ink light means that the printer does not recognize one of the ink cartridges. Power the printer off, pull out the power cord, wait for awhile, replug and turn the printer on. If the light no longer blinks, ok. If not, try installing another cartridge pair if you have them available - even if they are old used ones. If the ink light continues to blink with different cartridges or if you don't have any different cartridges, old or new, you have a dilemma. Do you want a new printer or do you want to continue to chase this problem. To chase this problem, get new cartridges and install them (half the price of a new printer). If that works your set, but if not you need to have your printer serviced which is doubtful that it is worthwhile doing so.
Mar 03, 2011 | HP DeskJet 810c InkJet Printer
The cartridge indicator light continue to flash even after changing the cartridge. What could be wrong?
Often times. the cartridge is not seated properly, so take out the cartridge and put it back in again. Make sure it clicks in place. Also, make sure that the protective tape is removed from the ink ports on the new cartridge..
If this does not work, do a reset by holding down the power button on the printer for a few seconds. Remove the power cord from the printer and wait a few minutes before plugging the printer back in and turning on the power.
If this solution was helpful, please remember to leave positive feedback for me.
Thanks,
Brian
Jan 23, 2011 | HP DeskJet 932c InkJet Printer
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    Blinking orange light on hp 932c
    Solution
    1. Check to ensure that the top access door is firmly closed.
    2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
    Solution two:
    1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
    2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
    3. Turn the printer on.
    Solution three:
    The print cartridge carriage is stuck.
    Solution
    1. Open the top access door on the printer.
    2. Remove the ink cartridges.
    3. Turn the printer off, then on again.
    4. Replace the ink cartridges.
    5. Close the top access door.
    Solution Four:
    Issue
    The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
    Solution
    1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
    2. Insert the module into the back of the printer.
    3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
    4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
    Jun 17, 2009 | HP DeskJet 932c InkJet Printer
    Flashing on/off light on hp deskjet 3520 printer
    Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
    c00374282.gif Solution
    Close the cover.
    Cause
    Printer cover is open. Solution
    Insert appropriate media in the In tray.
    Cause
    The printer is out of paper. Solution
    • Change the printer's print mode setting.
    • Change the printer's paper type selection.
    • Use a different brand of label media.
    Cause
    The printer has difficulty picking up label media. Solution
    Follow each of these steps until the problem is resolved:
    1. Remove the paper from both paper trays.
    2. Press the power button once. Wait a moment for the paper jam to clear.
    3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
    4. Remove the rear access door.
    5. Remove the paper jam through the opening at the back of the printer.
    6. Replace the rear access door.
    7. Reload the paper into the paper In tray.
    8. Print the document.
    Cause
    There is a paper jam. Solution
    1. Remove and then reinsert the print cartridge(s) into the printer.
    2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
    3. Manually clean the print cartridges and print cartridge cradles:
      • Open the printer cover and wait until the carriage moves to the center.
      • Press the Power button to turn off the printer.
      • Disconnect power cord from the back of the printer.
      • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
      • Lightly moisten a cotton swab with distilled water.
      • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
      • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
      • Reinsert the print cartridges.
      • Close the printer cover.
      • Connect the power cord to the back of the printer.
      • Press the Power button to turn on the printer.
    4. Calibrate the print cartridges.
    5. If the light is still flashing, replace the print cartridges.
    Cause
    There is a problem with a print cartridge. Solution
    1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
    2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
    3. Remove and then reinsert the print cartridge(s) into the printer.
    4. Print the document.
    5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
    6. Try printing again. If the problem continues, replace the print cartridges.
    Cause
    The print cartridge has partial loss of electrical interface with the carriage connections.
    Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
    DISK WON'T LOAD, TURN ON AND ALL THE LIGHTS CONSTANTLY BLINK
    Clear any paper or carriage path obstructions Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed paper jam removal instructions, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams (c00095617).
    1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
    5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6. Press the On button to turn on the product.
    Plug the product directly into a wall outlet Follow these steps to make sure that the product is correctly connected to a suitable power source.
    1. Make sure that the computer and the HP All-in-One both have a three-prong power plug.
    2. Remove the power cord from any power strips or surge suppressors, and plug it directly into a grounded wall outlet.
    Perform a partial reset A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
    1. Unplug the power cord from the unit.
    2. Reconnect the power cord into the unit.
    3. When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
    4. When only the On/Resume light is flashing, release the buttons. When the On/Resume light is steady, the reset is complete.
    5. Try the print job again to see if this step resolved the issue.
      • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
      • If the issue is not resolved , continue to the next step.
    Remove and re-install the print cartridges Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
    1. With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center. The print cartridge carriage is the plastic part that holds the print cartridges. When the carriage is at the center of the access area, unplug the printer.
    2. Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
    3. Reinstall the print cartridges.
      • The black or photo cartridge goes on the right.
      • The tri-color cartridge goes on the left.
    4. Close the cartridge access door, plug the printer back in and turn it on.
    Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Oct 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Zvonko jelusic from belgrade
    The print carriage is stuck.
    Solution
    2. Remove the print cartridges.
    3. Close the print cartridge flaps after removing the print cartridges.
    4. Turn the printer off and then on again.
    5. Replace the print cartridges.
    6. Close the top access door.
    If the resume light continues to blink after the print cartridges are released,
    OR
    the print carriage is stuck or makes a grinding noise, follow these steps.
    Solution
    1. Lift the top cover to the printer.
    2. Turn the printer off and then on again.
    3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
    4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
    5. Take out the print cartridges and close the top cover.
    6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
    7. Open the top cover, reinstall the print cartridges, and then close the top cover
    Solution
    1. Open the top cover.
    2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
    3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
    Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
    Flashing lights
    That flashing pattern is consistent with a stuck carriage. Here is a copy/paste from HP concerning the 5000 series and your flashing lights.
    Issue
    Solution
    3. Close the cartridge flaps after removing the ink cartridges.
    4. Turn the printer off, then on again.
    5. Replace the ink cartridges.
    6. Close the top access door. Issue
    The Resume light continues to blink after the cartridges are released.
    OR
    The carriage is stuck or makes a grinding noise.
    Solution
    4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
    5. Take out the cartridges and close the top cover.
    6. Reconnect the power cord to the back of the printer. Plug the power cord to the wall outlet.
    7. Open the top cover, reinstall the cartridges, and then close the top cover.
    Oct 23, 2007 | HP DeskJet 5550 InkJet Printer
    Cartridge light
    Issue
    The CARTRIDGE light is always on.
    Solution
    2. Unplug the power cord from the back of the printer. Unplug the power cord from the power source. Wait one minute.
    3. Plug in the power cord to the back of the printer. Plug the power cord to the power source.
    Oct 08, 2007 | HP DeskJet 5150 InkJet Printer
    Lexmark X1270 All-In-One InkJet Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Sanath Kumar V
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
