Question about Sew Smart Compact Cordless 17390B Sewing Machine
Needle not moving
The needle on my Sew Smart is not moving up and down. I popped off the side cover and it's not attached to anything. You can move it up and down with your fingers. There are a couple of pcs. that are made of metal that are in the attachments box. One is rectangular with a hole and a tightening screw in the hole and the other is is round and about the size of a quarter. I think they came out of this machine.
    Scholar:
  • 41 Answers
Good morning,
Unfortunately, if the needle bar is not attached to anything, you'll need to return it to the dealer you purchased from for a repair/replacement (depending on how long you've had your machine). If the needle bar has become detached, it is not something that you can easily repair yourself (re-timing the machine may be necessary).
If you did not purchase from a machine dealer, and your machine is no longer under warranty, you'll need to check with the store you purchased from regarding their return/replacement policy. If they cannot take care of the problem, you'll need to find a local sewing machine dealer who will. Most authorized sewing machine stores have technicians who can work on just about any machine - and many do not charge for just taking a quick look to determine if it's an easy fix.
Sorry we don't have a better answer - that you can take care of yourself - but sometimes things happen that just require a professional tech to look into.
Good luck,
Kim & Linnette
Posted on Jul 23, 2008
Why does my Empisal sewing machine miss stitches , sew, miss, sew?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem,, the feeddogs may need to be checked to see why they are not moving the fabric thru the machine.
the
thettttt
the the
Aug 26, 2014 | Sewing Machines
My singer 1120 will sew straight stitch but not zigzag
If the needle is moving side to side the chances are it is a blunt or bent needle, failing that it may need retiming , I cannot upload timing instructions on here contact me kendourof@yahoo.com and I will attach instructions
May 27, 2014 | Sewing Machines
Bar that hold the sewing foot is loose
If the comment already posted did not answer your question, here is another thing to check. If the screw that attaches the foot and ankle to the presser foot bar is tight, and the foot can still be moved, it is likely that the presser foot bar has become loose within the lifting mechanism. You could save yourself some trouble by taking your machine to a sewing machine repair shop, but if you would rather avoid that expense, do the following. Remove the needle bar and take up mechanism cover on the left side of the machine. This is held on by a single phillips head screw on the back side of the machine, which, with the back of the machine facing you, should be on the top right side of the machine. Once this cover is removed you will be able to see two vertical metal shafts, one is attached to your needle clamp and needle, and should be in the front. The other is the presser foot bar, and will be behind the needle bar. There should be a small allen screw about halfway up that shaft that tightens onto the bar. With the presser foot properly positioned on the needle plate, tighten this allen screw. Don't tighten the screw too tightly, as this can damage the presser bar, just make sure it's nice and snug. Make sure the presser foot raises and lowers properly, and re-attach the needle bar cover.
Hope this helps.
Mar 16, 2014 | Brother CS6000i Computerized Sewing...
I have a Pfaff 1475cd when turn it on and try to sew it makes a grinding sound and will only sew a long straight stitch on any stitch - at first it would do it occasionally and then stop - but now it...
The problem is the swing stitch (ZigZag) arm actuator bar has either popped out of the servo motor that operates the swing arm. Or the connector is broken or servo motor is dead. When you turn on the machine the needle bar is suppose to do a little dance (couple of twitches back and forth) and the machine is ready to go. Yours grinds (not dancing) because of the swing arm bar is popped out of it's holder. Good news is ... it is probably not broken and just needs to be put back in place though it is worn and thus the reason it popped out. That swing arm bar is easily accessed just under the plastic tray in the top of the machine where the thread holder sits. Bad news is ... That thread holder tray is a PITA to get off with out cracking anything (lots of patience). There are just two small philips screws securing it **BUT** the carry handle , the top flip cover and the right end light cover all have to come out to remove the PITA tray . More Good News though ...you may be able to repair with out removing the tray by ... First (with machine OFF) try to just push the needle bar side to side a bit (like you are trying to make it ZigZag manually ) and listen for a click. Then turn the machine on (Power button ON) and watch for the needle bar dance ? (you just fixed it). Note, It does takes a bit of effort to move the needle bar side to side but don't force it hard. HTH robb
Dec 24, 2010 | PfaFF Sewing Machines
Kenmore 158.1703 sewing machine - needle not going up and down
Sounds like your worm drive gear is striped and needs to de replaced. If you twist the handel on the end of machine does the needle move up and down.
Jan 03, 2010 | Kenmore Sewing Machines
My brother PE-400 sewing quit sewing
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
Jan 02, 2009 | Brother Disney PE-400D Computerized Sewing...
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Sew Smart Compact Cordless 17390B Sewing Machine Logo
157 people viewed this question
Top Sew Smart Sewing Machines Experts
Bargain Box
Bargain Box
ray gallant
R.A. Ellis
R.A. Ellis
Are you a Sew Smart Sewing Machine Expert? Answer questions, earn points and help others
