Question about Jensen's VM9312 Car DVD Player
Vm9312 pink wire
Where does that pink wire go and how can i get it to work while the car is in motion. i can't figure out were that pink wire goes.. and i don't have a remote.
Just go to the source screen, hit setup, then hit 5,4,3,2,1,0 on the remote control and a screen will come up. touch the hammer and screwdriver button on the left and it will have a thing called parking brake bypass and set it to on and click the x, this way it doesnt matter if u have the pink wire attached to anything.
msheraton23@gmail.com
Posted on Aug 12, 2008
  • 1,586 Answers
Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's the peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 01, 2008
Can i run my pink wire on my jensen vm9312 to the ground
yes, that will bypass the safty feature and allow you to play a DVD while the car is in motion.
Note ; you can also just enguage the park brake ONE CLICK and achiev the same.
Nov 01, 2011 | Jensen's VM9312 Car DVD Player
Where does the pink wire on a vm9312 hook up to on a 2000 dodge durango
the pink wire is the parking brake wire... so should be hooked up to the paqrking brake...
OR , you can put a switch on it to bypass the safty feature.
Oct 07, 2011 | Jensen's VM9312 Car DVD Player
Where do i connect da pink wire
connect da pink wire to the ground wire on the stereo units wiring harness. This will tell it you are in park.
May 13, 2010 | Audiovox VM9312 Car DVD Player
Have a jensen linear phase car receiver , there is a light pink wire coming out of it what is it for ?
The pink wire is the safety wire so that you can not watch the screen (during a video) unless your car is in park. You can either connect it to a ground or completely bypass it by typing the code 543210 in the menu screen and turning the safety feature off.
Dec 12, 2009 | Jensen's VM9312 Car DVD Player
Where do I hook up the pink wire in a 95 Toyota
if the pink wire mark to brake just connect to a straight ground or to a switch to a ground in put to switch
Sep 15, 2009 | Jensen's VM9312 Car DVD Player
Vm9312 in dash will not play video
Go to your radio tuner screen and go to your set up page then use your remote and press 5,4,3,2,1,0 and hidden menu will pop up then you will have to press the tool looking button on the left side of the screen and it will give you an option to it off so you dont have to hook up the pink wire.
Nov 17, 2008 | Jensen's VM9312 Car DVD Player
How do i watch movie while driving
go to the radio press setup on your remote then press 543210, a secret screen will pop up press the hammer and skrewdriver,u will see brake overide put it on the on position,thenpress the X at the bottom of the screen,then your all set.
Jul 07, 2008 | Jensen's VM9312 Car DVD Player
Vm9312 jensen dvd bypass
I just hooked the pink wire directly to the same ground spot as the head unit and it works fine
May 05, 2008 | Jensen's VM9312 Car DVD Player
Jensen VM9312 Bypass Code
trust me that works i just installed this deck in my truck today. And no you dont have to do anything with the ebrake wire at all just cut it off. Make sure you hear the beep sound when you hit 543210 you should hear it each time.
Apr 16, 2008 | Jensen's VM9312 Car DVD Player
Video
hook the pink wire to the ground
Dec 16, 2007 | Jensen's VM9312 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
570 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
