Question about Sony KV-32FV27 32" TV
Sony KV-32FV27 Picture Discoloration
I have a small (3"X3"), greenish discolored area in the top right of my screen. It is much more pronounced when the background is lightened or white. It dose not appear to be interference from surrounding devices and is consistent regardless of input source. Repair
  • 2,323 Answers
It appears that the greenish discolored area could be cause by the Yoke or it could also be some magnetization on the screen as well.
If it's the yoke that moved slightly out of position, it can be adjusted, but i would suggest to let a repair tech do it due a high voltage around the area.
Try unplugging the TV for some time and plug it back in and hopefully the demagnetizer circuitry might be able to clear the greenish spot.
Let me know if you need further assistance.
Posted on Jul 01, 2008
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen discoloration
try going to this link - http://www.retrevo.com/support/Mitsubishi-WD-62531-TVs-manual/id/564ag724/t/2/ all tips and tricks in troubleshooting your HDTV you may find it here. Hope this Helps...
Nov 03, 2009 | Televison & Video
Red band at top of tv
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or that red band you are getting.May the Lord Jesus bless you!
Oct 20, 2009 | Sony Televison & Video
2002 27" SONY Trinitron. Half-screen picture with bright line.
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony tv picture problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Oct 25, 2008 | Sony KV-40XBR700 40" TV
Sony KV-24FV12 picture problem
Alright, TV has hardware problem in Horizontal section and I would suggest to set Picture Quality as Soft Mode.
Jun 20, 2008 | Sony KV-24FV12 24" TV
Side shadows on picture
it sounds as if there are speakers to close to the tv or the built in speakers are not magnetically sheilded properly (maufacturer defect) if u have or have ever had speakers on the left and right side of your tv then the magnets in them will discolor and distort the screen. sometimes even long after the speakers have been moved away from the tv it will still look that way. you may try going to the library( or online )and looking in tv repair books on how to build a homade degauser unless your tv has that feature built into it in the menu somewhere like some computer monitors do. I had placed the front speaker of a 5.1 surround sound system on top my tv and it cuased that same problem, but i found out that by placing a small round magnet with a hole in the center on top of the tv (after removing the speaker for good) right where the discoloration was.. had to flip it one side or the other to get proper effect...it immediatly took away most of the discoloration and over time it disappeared. I hope this helps. Please email me at agclay777@comcast.net as to your conclusion in case it will help others. thanks, Adam
Oct 10, 2007 | Philips 51PW9303 51" Rear Projection...
Screen discoloratiom area
It's definitely your VCR that is causing the problem. Move your VCR, if you don't get any results you need to send it to repair.
Jul 10, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Blue discoloration
I have replaced alot of these light engines for this problem. Yesterday I received a letter from Sony saying they are going to give an additional warranty to have the optics replaced. I just checked, your model is one of them and Sony is replacing the optic block under an extended warranty, regardless of the purchase date, until the end of October 2008. Contact Sony for an Authorized Service Center in your area or go to this site to read about it: http://esupport.sony.com/perl/news-item.pl?news_id=185&mdl=KDSR60XBR1 Have this repair done on your set and it should save you about $1300.00 to $1500.00 on the repair. Hope this helps.
Mar 28, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KV-32FV27 32" TV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
