Question about Video Game Consoles & Games
Civilization game help
Started to install put in third cd to finish installing and computer tured off. i can play it but the computer says its not installed. i bougth the expansionpack and cant install. the computer wont let me unstall the game or re install it.
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey tycoon211,
If your computer lost power before installation could be completed, some of the files that were being installed may have been damaged or corrupted. Unfortunately, this means that the best solution to peruse may be dictated by the error messages (if any) you are receiving when you attempt to play or uninstall the game.
In many cases, damaged files should be limited to the actual game installation files themselves, but problems have been known to surface in temporary directories, the Windows Install Shield program and even a computer's registry when such problems occur.
As such, the first course of action I would suggest would be to write down any error messages you see when you attempt to play, install or uninstall the game. Once you've done so, you may wish to contact the technical support hotline for the game publisher to see if any diagnostic tools or FAQ's are available for the errors you have encountered.
Next, you may need to manually remove the entire program from your computer in order to reinstall. This can typically done by accessing the "Add/Remove Programs" option found within the Control Panel of most Windows versions, but you may also need to delete any folders left behind in your "Program Files" directory in order to reinstall the game.
If neither of these steps help resolve the problem and you are still unsure how to proceed, I would strongly recommend contacting your local computer repair facility for further assistance. While registry, Install Shield and other errors can often be corrected, you do run the risk of causing further damage to your computer if you attempt to make any changes or corrections with which you are unfamiliar.
Hope this helps you out.
Go Ahead. Use Us.
Posted on Jul 08, 2008
Unable to locate file, the data path appears to be incorrect, pleas check your data path After i open the game
The game's installation seems to corrupt. Try re-running the game's setup file and - whenever possible - choose the 'Repair' option ...
Jun 27, 2014 | Midway Home Entertainment Rise & Fall:...
Problem with Rise & Fall: Civilizations At War for Windows 7. how to open ebooklibrary.exe
To install and run "R&F Civilizations at War" in Windows 7:
1) Run the Setup file and install the game
2) Google and download "" and "".
3) Install "Rise and Fall: Civilizations at War Patch v1.15 beta".
4) Run the game, let it install required libraries and then reboot.
5)Run sfdrvup.exe and update the protection driver. Reboot.
Now the game should run in Windows 7.
Jan 08, 2012 | Computers & Internet
Problem running Civilization IV with Windows Vista
Okay, i play Civ IV on my system and i run Vista as well. Your best bet is the tweak with the compatibility. Find the install folder and look for the .exe that launches the game (civ.exe i think, don't hold me to that though). Right click on it and click on properties, then the compatibility tab. Try dropping the compatibility to win xp and see if that helps. If it doesn't, post your system specs and we'll work from there
Jul 25, 2010 | Take 2 Interactive Sid Meier's...
How to install sims double delux
open up disk drive put cd in auto start if not starting up go to my computer right click your cd then click auto play enter serial let it install and you can play
Jul 19, 2010 | EA - Electronic Arts The Sims Double...
Compatibility problem with rise and fall civilizations at war
get a vista patch off the internet and install to your directory, it will afterwards work, i had the same problem :)
Dec 13, 2009 | Midway Home Entertainment Rise & Fall:...
I dont no how to install my sims2 onto my pc
I want to put my ipod playlist onto my Sims me please!!
Jul 08, 2009 | EA - Electronic Arts The Sims Double...
Ea ssports cricket 07
dear friend .
you need to insert the cd for cricket 2007.
(it may be two cd pack)
insert the cd1 then autoplay starts .
and starts installing if it does not start automatically.
double-click on your cd/dvd drive.
after it starts it asks for key which u can get from
crack folder and right click on rid07 aand run as .
it generates the key which then can be used for the installation.
after that it asks for cd2 insert it and finish installing .
for playing u need to copy all files form crack folder.and paste them in your EAgames/cricket07 and replace existing file.them u can play the game.
thanks for reading the solution.
Mar 27, 2009 | EA Sports Cricket 07 for Windows
CivilizationII test of time
If it doesn't work the regular way, try installing and playing in compatibility mode. To install in compatibility mode right click on setup -> properties -> compatibility tab -> check: run this program in compatibility mode; to play the game in compatibility mode do the exect same thing ond the game executable file
Mar 17, 2009 | MicroProse Civilization 2: Test of Time...
My dell 3000 wont play games
If the cd is not starting on its own, click on "My Computer" then click the drive letter the cd is in. This will usually launch the installer. If not look for a setup.exe or installer.exe file after double clicking the cd's drive letter.
Hope this helps
Dec 12, 2008 | Dell Dimension 3000 PC Desktop
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
