Question about Mitsubishi VS-45607 45" Rear Projection Television
Turns on then turns off
My Dad has had the Mitsubishi VS 45607 for some years and he LOVES it until today. My Dad is 74 and a day without TV is like a day without air...LOl.. Anyway, when he attempts to turn on the TV, the green light comes on and the TV sounds as if it clicks on but it immediately turns off ( in a quick second). I any suggestion?
  • 2 more comments
  • justinkriter Jul 01, 2008
    im having the same problem but with a vs-60607 got it free becouse it did not work got home pluged it in and it came right on good picture sound everything worked good for a couple of days then when youtry to turn it on the timer light flashes once and tv turns right back off. removed front and back panels looking for a short did not find any thing but then tv worked again for about 2 days now same problem
  • chattiemom Jul 13, 2008
    I have been having the same problem with this tv as well.. The picture is great and sometimes it works great for days or even weeks.. then it just shuts down again.. sometimes unplugging it helps.. sometimes we just have to wait.. It was mentioned that the high voltage capacitors were the problem is this something that can be replaced? Has anyone had any luck in figuring out the problem
    Barbara
  • Anonymous Jul 21, 2008
    same problem
  • dblancoed Jul 28, 2008
    you turn on the tv it makes a click and in seconds goes off
I own the Mitsubishi VS450607 model and and the set works good then automatically shuts itself off. Sometimes after two hours of viewing then sometimes after eight. Very unpredictable and very unstable. I have spoken to a repair shop and they suggested I remove the front panel where the speakers are and look at the circuit boards. They had suggested if I see a white powdery substance then that meant leaky tubes on the board and the unit was shot. They gave me two other reasons which I can't remember but, When I opened the front panel I did not see any leaky tubes or white powder on the boards but, I did see three main tubes in the front that were covered with a black dust. I cleaned these tubes with a soft cloth and for some reason the set is now working fine. It has been four days now without any problems.
The repair facility was suggesting to wait until the set shut off again then call them in so they can actually see what was going on. Repair cost quoted $200 labor minimum plus $89 service charge plus parts another $100 or so.
Worth the expense I figure but set is working fine after I have cleaned off dust on main tubes.
Hope this helps.
Posted on Jul 12, 2008
Fortunately I have a friend who repairs big screen for a living. Also I am an equipment service tech myself. More than likely the problem lies in the hi-voltage board. The capacitors are shot. You will need to locate that main Power / Hi-votage power board and that should take care of the problem. Keep in mind I would only do this if your picture is in ecellent shape.
Posted on Jul 11, 2008
I had the same problem with my VS 45607,luckly I unplugged it for about 1 hour and tried it and thank God it's still working.
Posted on Jul 09, 2008
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-5046
i have a 50in mitsubishi tv model vs5046 the screen protector is crack the tv works fine but need to know where can i purchase a protector or its there a number. also how much will this cost.
Oct 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607
YOU HAVE THE DREEDED CAPACITORS GOING OUT...AFTER A FEW YEARS-THE CAPS LOOSE THERE PURPOSE AND DEPENDING ON WHAT CIRCUIT THERE IN --YOU WILL SEE THE ASSOCIATED PROBLEM,,,EXAMPLE--COULD BE SOUND ,PICTURE (YOURS) OR VERTICAL(PICTURE CLOSING UP) ETC... YOU CAN HAVE CHECKED BY A REPAIRMAN BUUUUT ,MAY NOT BE COST EFFECTIVE ,,TUNICA
Oct 24, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi projection tv
GOOD DAY; THE VS-45607 Model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. GOOD LUCK, big IRISH.
Aug 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607
Good Day, rmorales;
Does the buttons on the front panel work properly? I would suspect a bad button assembly.
I hope this helped, good luck, big IRISH.
Jul 22, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi TV VS-45607
Good Day;
This model is known for the front control panel going bad. You could unplug it, control panel cable, from the front of TV, by removing the speaker grill, and just use the remote.
Good Luck, big IRISH.
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Reasonable Price Quote for Repair?
Good Day;
In my estimation you paid too much the first time. The TV is 8 years old, buy new TV. The average cost is about $650.00.
May 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
