Question about GE GSS25XSRSS 36" 25.4 Cu. Ft. Side-by-Side Refrigerator w/ Tall LightTouch Dispenser, FrostGuard T...
GE GSS25XSRSS This morning the fridge stopped cooling the freezer and the digital readout said 29 degrees. I pushed the button that read "Turbo cool" and it seemed to stop everything... what do I do? I want the freezer around -2 degrees where it was!
SOURCE: Freezer and Fridge side not cooling
check the condenser is not blocked with fluff, it is situated iether behind the lower front trim panel or in the back near the compressor depending on the exact model also ckeck the fan near the compressor in running freeley.
Posted on Sep 01, 2007
  • 709 Answers
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website
Posted on Sep 25, 2007
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Posted on Sep 21, 2008
SOURCE: GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Posted on Mar 01, 2009
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
I have a GE mdl PSI23SGRCSV side by side. initially the digital temp displays for both freezer and fridge sides went to 16 on freezer side and 43 on fridge side. This happened almost overnight it seemed....
it may be that your fridge is now low on freon the techs now do not know what to do the best thing to do is to call the tech and ask them to test the compressor pressures and see if it is low on charge. unless you know how to take the lower back panel off (the one that is probably cardboard) and feel the lines on the compressor and see if it is really cold and really hot that means that it is cooling properly but if it feels a little warm cominv out of the cooling side and hot on the return side then you need more freon.
Mar 04, 2011 | Refrigerators
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Feb 17, 2009 | GE Profile Arctica Stainless Steel Top...
GE Side BY Side keeps Running
two reasons I can think of, fan motor because of the whining description you descibed, and possible freon leak. I think the first is the problem!
Dec 27, 2008 | Refrigerators
Hi Guys, I have a GE Profile Frig: PSF26NGTDBB Serial # SL416129 This AM the softdrinks seemed a little warmer than usual. We checked the digital temperature inside the frig compartment and the freezer...
HI thanks for your question. the problem is either that the fan in the freezer is not working, or the fridge is frosting up, or the coils at the back of the fridge are dirty. first clean the coils .it could be you problem. thanks the appliance doc please rate my answer . thanks.
Oct 09, 2008 | GE Refrigerators
New GE profile refrigerator bottom freezer model pfss6pkwass. Will not run, stuck in display mode. Lights are on but when setting temp on panel it goes back to off after a few seconds. After spending...
Ok, I had the same problem with this fridge. It is in "demo" mode. You have to push in and hold the Energy Save and Adjust Freezer buttons at the same time. Hold these in until the display starts flashing. You should hear the compressor kick on. I did this, and it was fixed and started cooling in a matter of seconds.
Aug 13, 2008 | Refrigerators
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25XSRSS 36" 25.4 Cu. Ft. Side-by-Side Refrigerator w/ Tall LightTouch Dispenser, FrostGuard T... Logo
116 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
