Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
No audio or video but LED blinks 5 times
Repair shop said "defective PCB module". I have replaced P board, D board and P-A board (in that order with no change in number of blinks) on recommendation of repair manual (noticed some minor design differences on P-A and D boards.
Replaced boards with brand new boards from a TV with broken screen. Used ESD precautions.
Can hear relay energize when 1st plugged in.
What next???
Thanks,
Jeff
    Master:
  • 638 Answers
This is the link to help you with a to z diagrams.have you connected the board perfectly you can look into it each and every part description in brief with exact knowledge.you can fix any type of problem you are facing.your problem is mentioned between pages 40-49, but i will suggest you to refer from page 1 to know about each and every part.
http://www.pasctraining.panasonic.com/pass/elearn/files/Plasma/9th_Generation_Plasma_Display_TV.pdf
you have to check
sos line----sos-5, line monitored---- 5v, problem occurs--- 5 blinks
pls do not forget to rate the solution as "FIXYA" SIR
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
wish u success .bye.
Posted on Jul 01, 2008
    Genius:
  • 2,035 Answers
Did take the same model board from other TV ,some different tv model is not compatible with tv's they differ make and model , you need same model board in order to work on your tv..
Certainly, I can help you. I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
  • Anand Kumar
    Anand Kumar Jul 01, 2008
    When it shuts off. Try doing what's called a self-diagnostic test.
    As soon as the television shuts try these steps.
    Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
    activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
    has occured since the last Initalization.
    Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
    ? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
    ? The flashing then pauses for approximately 1/2 second.
    ? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
    ? The Error Code is repeated a total of 5 times.
    Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
    times.
    The Error Code designations indicating a malfunction, or no malfunction, are listed below:
    Self Diagnosic Code Description
    1 - 2 = no error detected
    2 - 1 = X-ray protect (high voltage or beam current)
    2 - 2 = Short protect (short protect monitors low voltage supplies)
    2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
    2 - 4 = Vertical protect (usually loss of vertical from the source).
    Good luck.........
    Guru:
  • 1,894 Answers
Does the unit start or what?
does the unit start fully and shut off??
BTW what was the blinks pattern??
What is the error code for 5 blinks for a Sony KDL70R520A LED TV?
The most common defect that causes a 5 blink error on this model is the T-Con board. This board is now discontinued. You might be able to find one on Ebay or Amazon. If the T-con board does not fix the issue, then your panel is defective and your TV will need to be replaced.
Apr 09, 2016 | Sony KDL Televison & Video
Power LED blinks 9 times
There should be a problem with its audio output board. 9 blinks denotes it. For more details <http://electronicshelponline.blogspot.com/>
May 23, 2013 | Panasonic 32 TCL32C3 32 LCD TV
Picture went out and no audio, red light on power blinks seven times and repeats.
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Forcing audio only signal through component
You cannot get AUDIO from Component Video, as it is only VIDEO, you must get another set of Cables RED & WHITE, and connect them from the AV, AUDIO Jacks, OUT on the "Sender" to the AV AUDIO IN on the TV. So you will have 5 Cables connecting BOTH Video & Audio. The Component Video, uses Blue, Green, & Red, these go color to color on the RCA Jacks at BOTH ends PLUS the Red & White Audio, color to color at BOTH ends. .Hope that clears things up.
Feb 14, 2010 | Samsung LN-S4051D 40 in. LCD Television
Sony Bravia KDL-52XBR9 wont turn back on red led flashes unless I uplug and plug back in. Did firmware upgrade to newest aa0143pn, still happening.
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Nov 16, 2009 | Sony BRAVIA KDL-52XBR6 LCD TV
Philips 42PF7220A/37B shuts after 10-15 min. LED Blinks 5 times
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 19, 2009 | Philips 42PF7220A 42 in. Plasma Television
Tv red blink no start42 plasma philips
May 07, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Jan 24, 2009 | Panasonic TC-32LX70 Television
Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Jun 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
Picture and sound cuts off ,greem stb light keeps blinking TV turns on after 30 secs shuts off after 30 secs comes back on. Continious loop
How many blinks do you get? Depending on the amount of blinks you can figure out what the issue is.
If it blinks 6 times you can get the fix at
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
They have other fixes for E60A20
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70&keyword2=electronics
Dec 28, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
128 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
