Question about Refrigerators
Amana Refrigerator I have an Amana - DRS2662AW Refrigerator, and I noticed that it isn't cooling anymore. When I turn the cooling controls off then back on it sounds like it wants to come on, but then clicks off. What could be the problem and is this a DIY?
  • Anonymous Nov 12, 2008
    This is the 3rd time my compressor has gone out!!! I'll neve buy another Amana again!!
  • 481 Answers
It sounds like a bad:
  • start switch (on the side of the compressor) or
  • compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
  • so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 01, 2008
My Black Amana sxs Model SCD25JPW Fridge isn't cooling. Both sides are hot
OK, lets try a couple of things before you run out and buy a new unit. On that unit I believe the defrost thermostat is on the front bottom of the unit. Turn the little dial til it clicks and tell me if the unit kicks on.
Nov 30, 2012 | Amana ABB1921DE Bottom Freezer...
Amana refrigerator bottom freeze is not cooling; about 8 years old; the cooling switch was replaced and still does not cool
Kim pull refrigerator away from wall and unplug power. Remove lower panel that cover compressor and condenser fan and condenser coils. Don't wait too long but feel the top of compressor and tell me if cool, warm or too hot to hold had there. Let me know those results as I gather up the possible problems that could be related. Did you by chance check the defrost timer by turning timer through opening below and behind the Control panel=> ARB2217CSR Control Panel Did you say you changed a switch or thermostat here? See the defrost timer in photo at location 12? Try turning clockwise slowly until compressor starts or stops what ever may be happening. If stuck in defrost the timer part number=> 67001036 Defrost Timer It is possible that is the only problem but I will wait until I hear from you on turning the defrost Timer and feeling the top of compressor. If this post is helpful please rate, Thank You, John Tripp/AKA Sea Breeze
Nov 22, 2011 | Amana ARB2217CSR Bottom Freezer...
Amana drs2662aw has power going to compressor but the compressor doesnt start up
It can be the problem with compressor itself or problem with start up capacitor beside compressor. Click this link below for more details:---
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
This should help.Thanks.Helpmech.
Oct 26, 2011 | Refrigerators
I have a side by side ref/frez Amana ars266zbw the freezer works fine but the refridgerator isn't coolig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Amana ARS266ZBS Side by Side Refrigerator
Amana DRS2662AW Lights are on and I can hear the motor running but no cold air is coming out of vents. Freezer is defrosting. I have vacummed out coils on lower front.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 07, 2011 | Amana ASD2326HE Side by Side Refrigerator
Freezer too cold, fridge not working - Amana freezer on bottom
Something tells me you are right.
I'm sure you know that cold air seeks the lowest point, in your case, the freezer drawer.
About every combination unit I have ever seen uses a fan to 'stir' the air in a controlled manner and one or more adjustable vents to allow you to balance the distribution of the cooled air.
I'd place my bet on the failure of a (possibly Chinese) fan motor that isn't turning anymore.
Jul 26, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Drs2662aw amana side by side
Sounds like you may have a restriction or blockage, may also be low on freon
Aug 23, 2007 | Amana ASD2326HE Side by Side Refrigerator
Refrigerators Logo
299 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
