Question about Casio Exilim EX-Z77 Digital Camera
Lens error: camara has broken gears in lens assembly
The camara was dropped, now when it is turned on it makes a ticking noise. the lens extense half way out, then clicks again trying to retract back in. i disassembled the camara and lens assembly to find a broken gear. do i need more parts than just the gear assembly or can that be replaced by itself?
  • Ambrosia Nester Jul 08, 2008
    My camera is having the same issues - it was in my purse - inside it's case and when i pulled it out and tried to use it - it makes a buzzing noise and the light flashes and the camera says, "lens error". I just found out I am not able to use my warranty. What can I do to fix it?
    Problem Solver:
  • 12 Answers
Hi kevin3738 and a_nester
ok for kevin3738,
im thinking that since you said your lens doesn't extend all the way out that maybe you might have cracked a gear in the lens housing, the mechanism to extend that is located when you open the camera and take off the front face plate, on the right side of the lens housing **silver part** you see a black plastic casing attached to a motor on top and screws in it, that is what moves the lens housing in and out, in that are a few gears, i think 4 of them lat move the housing, 3 small ones and one big one that reaches down to the bottom of the housing, they are interchangable but im not sure as to where you could find a gear to replace the broken or cracked one,
And for a_nester
im gonna take a guess at what exactly the problem is on your camera, and it might be the lens autofocus
in that case you can look here
http://www.fixya.com/support/t780884-lens
or
http://www.fixya.com/support/t805636-cameras_lens_messed_up
Posted on Aug 03, 2008
I turn on my camara and then the lens makes a noise and it turns of right away,i charge the battery (fully) and it still turns off
maybe because you have a lens error trouble, Lens errors (system errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:wish you luck thanks
Feb 21, 2012 | Sanyo VPC-X1250 Digital Camera
My brench of camara name Powershot SD1300is digital. when i turn on with my canon camara i see lens error will shut down outomatic restart camara.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 23, 2011 | Canon PowerShot A560 Digital Camera
The proble is that my camara has the lens outside, when I turn on my camara appear a message that say lens error m627-31 y then the camara turn off
the motor that drives the lens must be damaged, u need to take it to the local service center to get the camera repaired.
Apr 14, 2010 | HP PhotoSmart M627 Digital Camera
I dropped my camara and now it says lens error, restart camara
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 10, 2009 | Canon PowerShot A550 Digital Camera
The zoom lens will not retract when you turn it off, subsequently an error message (E18) apprears when you turn it on. the camara store wants $150 to fix it......is this something I can fix myself? Thanks...
Jul 02, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
My l200 camara lens is stuck
huSh now :( I remember my former camera.. XD
Lens errors are fairly common. Usually it's sand or grit interferingwith the lens extension mechanism. Or the camera's been dropped withthe lens extended. Or the camera has been powered on, but the lens hadbeen blocked preventing its extension. Or the battery ran down with thelens extended ...
Here's some things that you can do to try to correct it. They only seemto work for less than 50% of the lens errors, but if the camera is outof warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12...
hope this will help ya out
Jun 06, 2009 | Samsung L200 Digital Camera
Cannon sd880
Jan 13, 2009 | Canon PowerShot SD880 IS / Digital IXUS...
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Casio Exilim EX-Z77 Digital Camera Logo
177 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
