Question about Maytag M7DH45B2A Dehumidifier
Goes off and on all the time without drawing any water?filter is clean
I bought the unit a year ago worked great this year it isnt working at all?the unit goes off and on all the time i can hear the compressor go on then off keeps doing this?what is the warranty on this model?
    Problem Solver:
  • 10 Answers
CONTACT YOUR LOCAL "MAYTAG REPAIRMAN". THEY WILL NOT ONLY TELL YOU WHAT IS WRONG WITH IT BUT WILL ALSO, SELL YOU THE PART AND TELL YOU HOW TO INSTALL IT. IF IT IS SOMETHING SIMPLE, THEY CAN OFTEN TELL YOU HOW TO REPAIR IT OVER THE PHONE. GOOD LUCK...........JLR4
Posted on Jul 01, 2008
The unit compressor is not working. I bought the unit new about a year ago. The fan and console are working, but no condensation occurs.
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If yours is an analog unit
(No LED screen) turn the humidity extraction knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this will help you troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 16, 2011 | NewAir AD400 Dehumidifier
I bought this unit on 13 August 2009. The unit runs, the bucket is in place, the filter is clean, but it doesn't remove any moisture from the air. The unit is in the basement in the exact same place it...
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
level
problem.
I hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 29, 2011 | LG Dehumidifiers
The 54501 dehumidifier i have is 4 years old it worked good last year and I remember turning down or up the humiity setting, now this year I don't seem to be able to get it to pull any water. I had it...
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manual unit with
no led screen, set the manual control to Maximum.
the unit without the filter. The filter should be cleaned once every two weeks.
Most dehumidifiers do not work well between those temperatures
level
in basement applications . Raising the unit up off the floor,
problem.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Kenmore Dehumidifiers
Dehumidifier not drawing water from air
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the Unit, before removing to inspect
and clean it, if necessary. If washed, allow filter to completely dry before reinstalling. DO NOT
operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
5. Ambient air temperature at floor level is between 40 - 60 degrees F. Dehumidifiers do not work
well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to
basement applications, where the air temperature at floor level is colder than at shoulder level.
Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Jun 22, 2011 | Haier Dehumidifiers
Dehumidifier is less than a year old. runs constantly but isnt collceting water. air filter was very dirty. cleaned it. now waiting to see if thats it or the unit is bad
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 11, 2011 | Haier 45-Pint Dehumidifier
Can't get down to the targetted humidity level
THIS UNIT HAS A REMOVABLE WASHABLE FILTER.. IS YOURS MISSING? IF NOT REMOVE FILTER AND CLEAN IT... TAKE OUT THE BUCKET IT IS RIGHT ABOVE WHERE THE BUCKET SITS...
May 05, 2010 | LG LHD45EL Dehumidifier
Everything seems to run fine, just hasn't pulled a drop of water
remove the back airfilter, and touch the tubes while the unit is running, if nice and cold, all is well, there just isnt any moisture there. but if compressor is running and tubes are warm , means freon/coolant has leaked out
Jul 22, 2009 | LG LHD65EBL Dehumidifier
DH runs but does not condense any water out of the air (bucket is dry). This unit was working well until a week or so ago when we had a lot of T-storms and humidity rose considerably. We went from having...
there are coils in the unit that the water folws across, you can take the filter out and clean the coils, this would help,but even though it is only 1 year old it can go bad,, if it is clean inside and everything is appering to be working it might have just gone bad and n eed a new one
Jun 28, 2009 | Frigidaire FDL25P1 Dehumidifier
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
46 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
