Question about Fuji FinePix F20 Digital Camera
Top buttons don't work
Camera won't turn on, nor take a pic.. before taking the battery out ( and the lens closing) it would show all images, and menu would work. Now it is a paperweight.
Any help??
  • mosupra Jul 26, 2008
    My daughters mildly used F20 won't power up even with fuly charged battery. I also have an F10 that I've never had a problem with. The green right arrow button on the back will turn the camera on and with function fully but only if this button is pushed continuously. This of course is not a fix just an observation that tells me that all the functions are working except the power button. I have taken it apart and found no apparent problems burned contacts ect, but no fix either.
    Problem Solver:
  • 5 Answers
Sounds like a button is stuck in.
Posted on Aug 11, 2008
My lcd display won't show the camera image while taking pics but it will show the menu and previously taken photos by pressing the play button. What could be wrong?
Turn the camera on, and press the DISP button on the back of the camera. This turns the LCD screen on and off. The idea of this button is to save battery power (you would then use the peep hole optical viewfinder in its place).
Dec 14, 2012 | Canon PowerShot SX30 IS Digital Camera
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
When turned on just shows black screen. Used to be able to pwer off and back on and would work. Lens issue? Can view pics on memory card just can't take pics anymore.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 14, 2011 | Canon PowerShot S2 IS Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
My ex Z1000 wont take pictures. i turn the camera on the lens goes in and out some times it looks like its going to let me take a picture and then the lens closes back into the camera and the screen goes...
your camera problem has the problem chance. Fisrt you should try with full charge battery. sometime weak battery cause also. Second main pcb does not resetting every time after taking picture. I hope you luck! Would you give more detail problem...
May 21, 2011 | Cameras
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
The iris is probably shut closed or the CCD is bad. The iris controls the amount of light that enters the CCD (charged coupled device). Sometime the iris get moisture inside and cannot open. Or the CCD is defective. Leave it in a dry environment for a day. If it doesn't cure then return it to the store for a refund because the CCD will need to be removed and replaced.
Dec 16, 2010 | Samsung i85 Digital Camera
Canon xt menu button will not work. When I turn
I'm pretty sure I heard of those buttons going bad when I was researching used cameras...might have to get it repaired unfortunately...
Saw a few ads on craigslist etc. where person said "camera takes pics fine but menu button stopped working recently". Maybe there's a recall?
Aug 10, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Kodak Easyshare DX7630 screen is black and won't take anymore pic
your image sensor is bad it will have to be replaced by a camera technician .
Jun 03, 2009 | Kodak EasyShare DX7630 Digital Camera
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. Groove_us@yahoo.com Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
Show only black when trying to take pic/video
This problem is caused by a stuck shutter assembly. Normally the shutter is open which allows light to enter the image sensor and show you the live preview you see on the screen. When you take a picture the shutter closes which allows the image sensor to record what was seen at the exact moment the shutter closed. The shutter is stuck closed, causing the image sensor to always be in the dark. These shutter assemblies are extremely small and delicate. The miniature parts can become jammed with just the slightest bit of oil or contaminant, or the slightest misalignment of components. The problem can sometimes be fixed by gentle tapping of the camera on a solid surface. If you are going to try this be VERY careful, and do not tap the camera on the buttons, lens, or battery door. If this does not solve your problem then the camera is going to have to be taken apart and the shutter cleaned and reset to allow free movement. This repair costs $125 to $145.
Jun 13, 2007 | Nikon Coolpix 3200 Digital Camera
Fuji FinePix F20 Digital Camera Logo
61 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
