Question about Philips DVP5140 DVD Player
PET824 Portable DVD player
DVD was working fine for the last couple of years, suddenly when I try to have it read a disk it will stay "Loading..." and will not start.
Any clue on what shoul I do with it!!
    President:
  • 173 Answers
Try cleaning the optical lens manually. Just eject the cd tray and unplug the dvd from power source and remove the casing > Take a cu-tip with a small amount of alcohol on it and you will be able to see the optical lens in the middle of the carriage > Clean it a few times and let air dry for about 1 minute > replace the case and plug it back in and try loading your disc.
The other problem could either be an alignment problem which you will have to take it to a shop because they have the tools to do it, but is inexpensive to have done about 25-30 dollars. The worse case scenario is your optical device is damages and has to be replaced, which you might as well buy a brand new one because they are rather expensive. Hope this helps and always try the simple stuff first. Let me know if I can be of further help.
Posted on Jul 04, 2008
Polaroid portable dvd player won't recognize disk
You have put a dirty CD in and now the laser lenses is dirty and cant read the finer details of a DVD.It needs a clean.
Dec 06, 2013 | Polaroid Televison & Video
No longer reads disks.
If you know how to take it apart, you can clean the laser lens with a Q-tip, and a little rubbing alchohol.
this will probably fix it.
Do NOT do this with it plugged in.
Can cause permanent damage to your eyes!
Dec 13, 2009 | Akai DVPS7000 DVD Player
Phillips Portable dvd PET824 won't play dvd; no picture or sound
you can try moving the laser lens that reads the dvd's just don't touch the lens just move that little square it's attached. all you have to do is move it back or forth just a little and leave it and try the cd and if that don't work just keep on moving it around until it reads. it'll work i had that problem on my dvd player and my playstation.
May 02, 2009 | Audiovox D1708 Portable DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Audiovox 8
So you're saying that already tried a lot of DVD but none of them is working? but this was working fine before is that right?
Aug 26, 2008 | Televison & Video
Won't read dvd
Try switching the LINE SELECT button from OUT to IN, then back to OUT. This solved the problem in which our Sony DVP-FX810 player showed LOADING for around 30-45 seconds and then CHECK DISC.
May 09, 2008 | Sony DVP-FX810 Portable DVD Player
No Disc message
Turn off the power.
Open the lid and gently push the laser mechanism to the outermost point of the slot.
Power on and try a disc again.
Also try cleaning the laser lens with a mild foam cleaner and cotton swap. Leave to dry and re-try a disc.
If neither work, then the laser is probably faulty. If the unit will play CDs but not DVDs, then this is a good sign of a faulty laser.
Mar 16, 2008 | Philips PET824
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
LG V8824
the small 12 tooth gear on top of the slide motor could have a crack in it , this will lock the slide from working
Sep 21, 2007 | Sony SLV-D350P DVD Player/VCR
Philips DVP5140 DVD Player Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
