Question about Dryers
Electrical question how many recepticals (plugs) can i put on a 15 amp circuit
    Scholar:
  • 121 Answers
Sound like the switch is dirty Inside. If you can find a replacement switch for a couple of dollers, and can replace this yourself, you will be fine. Other wise New Fans are saffer, as yours may be damaged due to trying to start with all the dirt in it.
Rian
Posted on Jul 28, 2008
I bought a AlohaBreeze Pedestal fan from yard sale, been told that it works fine. It did worked fine for sometime. Since it was too dirty, I tried opening it & cleaned it. Works fine for sometime but when switched off for a while & on it, I can just hear the motor sound but the blade doesn't move. If I open it & adjust the knobs, works out for sometime. Everything inside parts seem to be fine. Can anyone suggestion some solution that could make work fine thru'out.
Posted on Jul 09, 2008
My fridge keeps tripping the power
Your solution is one of two things.
First is the circuit you have plugged the refrigerator is either over its limit and the breaker is tripping because it is overloaded. In this case you will have to determine what load also share this circuit and eliminate the extra loads or move the cord to another circuit which is not overloaded. Most home circuit are wired with 14 gauge and is rated at 15 amps. When the circuit gets to 15 amp and more, the associated breaker trips to prevent overload.
Second, Your refrigerator may have a short and needs troubleshooting to find the cause. To see if it is a bad circuit try plugging into a circuit via extension cord to circuit in another room receptical. The reason I say another room, when electrical installers wire circuits, you can put several recepticles on the same circuit. If you plug your refrigerator in the same circuit you had it on before then you will get the same problem, your refrigerator tripping again. If your frig trips on a different circuit then troubleshooting the cause will normally require a tech.
Good luck and hope this helps.
Oct 28, 2014 | Refrigerators
Interior electrical outlet plugin
Typically ' cigarette lighter ' plugs are fused with a 15 amp fuse, so in that case 15 amps is the capacity for that plug. If you have an owners manual check it for the fuse rating for the lighter plug, or check the fuse box . There may be a list of fuses and what they are for. Some folks install auxiliary plugs with higher amperage ratings, say a 20 amp circuit. This would entail using a 20 amp fuse, the correct size wire, and a plug that is rated for 20 amps.
Mar 23, 2014 | Vehicle Parts & Accessories
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
Can I install on a 20 amp circuit with a 15 amp GFCI plug? The unit says 120 v 6 amp max
Jan 2013
1) Yes. With 6 amps.
It is not purely code, but generally not dangerous.
Most household outlets and switches sold at home center are actually rated 15 amp, and should be on a 15 amp breaker. just don't overload.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat
2) However if you are running close-to or higher amps than 15 amps, such as space heater (volts x amps = watts), then I would suggest installing 20 amp arc-fault breaker, and protect whole circuit.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
3) Add comment and say what you do.
Jan 22, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
Eton e5 sw shot
The SW FET preamp transistor, Q1, on the underside of the circuit board blows if a static electric discharge hits the whip antenna. In my case, a cat rubbing against me & the radio on a very dry winter day did it in. The back & circuit board has to be removed to get at it. The micro transistor & the solder connection are very tiny, so hard to replace. The antenna jack should still work, because the preamp is only for the whip antenna's SW reception. An easier solution would be to just run a wire from the antenna jack to the whip antenna, but you would no longer have the whip's preamp benefits, or just use a longwire antenna connected to the jack for SW. Also beware plugging into the jack disables the AM ferrite antenna inside, so you might not want anything plugged into it for AM reception because the internal ferrite seems to perform better than any external antenna.
Jan 17, 2013 | Eton E5 Radio
Lights & outlets in addition, how many on 20 amp breaker?
I would say something a little different than SmithBrother. You said you are putting on an addition and you asked how many outlets can you put on a 20 amp breaker. Because of the date on your comment, it is probably a little late to be replying but whaat the heck ... here goes.
I think there is a rule of thumb that you can put about 12 "holes" in a 15 or 20 amp circuit. A "hole" is a hole in the wall where a box would be put for a outlet or a light or a switch. I presume you know to use #12 wire on a 20 amp circuit and while you may use #14 on a 15 amp circuit, I prefer to shy away from #14 wire even though I MAY protect a given circuit with a 15 amp breaker. You can over protect but not under protect. 30 amp is #10 and so forth.
There are lots of other considerations ... too many to do justice in this short comment. However, I will hit a few hi lites. As SmithBrother says, a micro wave should have its own circuit as should a AC or a frig - I think that may go without sayng. I think you are speaking more general use. I believe the electric code says every wall must have a plug in it and you can go no more than 6 feet to get to a plug. So, if you have a 12 foot wall, one outlet in the middle will meet the requirement. There is nothting preventing you from puttine two outlets in that same wall. From my perspective, I want to have lots of outlets and I want them to be convenient for me to use. (There are more than 200 outlets in my home) Another thing, you cant put a outlete over a electric baseboard heater. You can put one at each end of such a heater but not where a lamp cord would lay in top of the hot heater surface.
Regarding the 12 hole rule ... if you have two switches that control the same light, you only count those two switches as one hole even though, obviously, there are two holes in the wall for the two switches. Count a second hole for the light. Conversely, if there is a light and a fan, you should count that one hole in the ceiling as two.
Mar 11, 2009 | Electrical Supplies
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Dryers Logo
232 people viewed this question
Top Dryers Experts
