Question about Danby DAC5020 Air Conditioner
New to me
I just need to know what icons on display mean what? Theres a finger pointing to a button an asterisk type icon. i just bought a used Danby and i did not get a manuel i just need to know how to get it going coldest possible way.
  • johnpat4 Aug 01, 2008
    Danby DAC 5020 how to drain the water from my air conditioner
3 Suggested Answers
  • 1218 Answers
SOURCE: I have bought a second-hand Danby Portable AC
http://www.danby.com/product.php?cod_prod=DPAC90061&code=4
Go to this web site. It is supposed to have a copy of the manual of your discontinued unit.
Hope this gets you what you want.
Posted on Jun 25, 2009
  • 4736 Answers
SOURCE: danby dpac 10071 air conditioner is not cooling.
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Posted on Jul 29, 2011
Undefined
When your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD is connected to a wireless network, you'll see a and-wififull.svg Wireless icon in the System icons at the top of the screen.
  1. Tap the and-home.svg Home icon at the bottom of the screen.
  2. Put your finger at the top of right of the screen and swipe down.
    The Settings shortcuts will appear.and-shade.svg
  3. Tap the and-settings.svg Settings icon.
  4. If required, tap the slider button beside Wi Fi at the top left of the screen. The button will turn blue and display On.
  5. Tap Wi-Fi. The list of available networks will appear.
  6. Tap the name of the network you wish to connect to.
  7. Tap Connect.
  8. If you see a lock icon beside the wireless connection, it means that the connection requires a password. You'll need to enter the password to connect.
Turning off Wi Fi on your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD You can turn off Wi Fi to keep your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD to keep from connecting to the Internet, which is also known as Airplane Mode.
Turning off Wi Fi extends your battery life, and also lets you use your Kobo tablet on an airplane or in a hospital.
  1. Pull and hold the power slider at the top of yourKobo Arc 7, Kobo Arc 7HD, orKobo Arc 10HD until the power off menu appars.
  2. Tap Airplane Mode.
Oct 27, 2014 | Tablets & eReaders
Word has taken over my computer; when I click on any program icon, Word opens
If you know when this problem started, I would recommend you use System Restore to go back to a restore point from before that time.
  1. In Windows, right-click on a program icon. Windows displays a Context menu.
  2. Choose Open With from the menu. (Don't choose Open; make sure you choose Open With.)
  3. If Windows displays another level of menu, make sure you select Choose Program. Windows displays the Open With dialog box. (See Figure 1.)
  4. In the list of available programs, select the correct program for that icon.
  5. Under the list of programs there is a check box labeled something like "Always use the Selected Program to Open this Kind of File." Select this check box.
  6. Click OK.
These steps change the file association for a single type of file-the type you right-clicked on in step 1. You will still need to check other file types to make sure they open with the proper program. If not, change the associations as described above.
Dec 13, 2013 | Microsoft Word 2010
Need to know how to get icons from top to bot
You just move the icons where you want them. Maybe you are saying your can't see all your icons. if that is so, go into the display under the control panel and change your screen resolution. The higher the resolution, the smaller the icons and more will appear on the display.
Jun 06, 2012 | HP Computers & Internet
I played music player and fm from my new samsung corby... the icons are being displayed in the home screen wen i come out of those applications.. i want to delete those icons on the home screen... how to...
you cant delete the icons,u must just slide it back into the margin on the lefthand side of the screen,theres a small arrow type of thing on the screen,u must click on that arrow to let the margin come out,then u can slide the icons in there,where they belong.
Sep 10, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Im using 32gb kingston pendrive its a gift so i dont know where thy bought. the Problem is, while inserting it denote as new hardware found later it denoted as hardware missing could u pls suggest me to...
first of all insert ur pendrive correctly n firmly into the usb slot wen the new hardware icon displays u just refresh ur computer by pressing the F5 button on ur keyboard do this nearly 5 times then wait for few seconds; once the new hardware is done installing ur pendrive is visible in "my computer"; double click on the new displayed icon and start using it .
If the above procedure doesnt work 1st time please do repeat it again ur pendrive will work for surelly
Sep 17, 2010 | Electronics - Others
Dell - No icons or start button
to get your Icons back try this.
  1. Right-click the desktop.
  2. Point to Arrange Icons By.
  3. Click Show Desktop Icons.
I would also try this.
Another quick shot, is goto Start, Run, type "msconfig", and click the tab saying DIAGNOSTIC. click apply, restart, and see if your icons are there.
Then I would run a virus scan. you could have a virus on the machine. I recommend MalwareBytes for virus removal. you can get it at www.Download.com
Jan 11, 2010 | Dell Computers & Internet
Camera fails to flash every time we take a picture
1.Turn off the camera.
2.Install a set of new or fully charged batteries into the camera. then turn it ON
3.Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash. a86196b.jpg
4.Take a picture. [If flash still doesn't work contact Kodak support line 1 800 235 6325 (23KODAK)]
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
Changed filter and need to know how to reset icon
Press the 'Timer' and 'increase button' simultaneously (3 seconds) to resume normal operation.
Nov 23, 2008 | Danby PHD DHCC6020 3-in-1 Home Comfort...
What does the sun Icon mean?
The sun likely means it is heating, snowflake would mean cooling.
May 28, 2017 | Heating & Cooling
Take phone out of silent mode sgh p520
PUSH BUTTON ON LOWER RIGHT HAND CORNER OUNCE.
PUSCH SPEAKER BUTTON ON LEFT HAND UPPER CORNER FOF MORE THAN 2 SECONDS
May 21, 2008 | Cell Phones
Danby DAC5020 Air Conditioner Logo
27 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
