Your timer could be broken.
But let's review.
Override set atTimer on > correct
When override is moved other direction, then lamp turns on.
Lamp fixture is turned on
Bulb is good
Receptacle has power
You tied timer on different lamp at a different receptacle.
Dial rotates with passing time, which indicates that clock motor is functioning
Dial does not get stuck during rotation, and makes complete 24 hour circuit in 24 hours, indicating that clock motor is not weak.
Segments up or down for timer functions >> here's what to do: pull up some segments. Manually rotate timer dial clockwise.
The lights will turn on-off as you rotate dial manually.
That will confirm if up or down is correct position of segments.
If everything above checks out, timer should work.
If timer is defective, exchange for another one.
I test these timers and 4-6% arrive defective. Most last one or two seasons and then they quit.
Some last years.
But timers today are priced low enough.
1. To Set Program:
Pull up one tripper
between hour marks
on the 24-hour dial
for each 1/2 hour of
ON time desired. For
example, if timer is to
be ON between 12-2
PM, all four trippers
between those times
must be pulled up.
2. To set time
of day: turn dial
clockwise with the
arrow head pointed
to the correct time.
The dark area
denotes PM and
the white area
denotes AM.
Straight out of the manual. Pull up trippers for all of the time that you want the device to run.
Rotate the time of day dial in the direction of the arrows.
The off/on dial will override the timer until it comes around to the on time again then the timer will control.
Good luck.
Gary
i am having the same problem this customer is having i did everything in the instructions and cannot get the timer to work
