Dell C640 change touchpad settings - Computers & Internet
  • 3 Answers
I read on this a while then found these 2 packages and downloaded from DELL's site:
I installed the R49155.EXE and got 2 more tabs in the properties window for my mouse (Start + Control Panel + Mouse).
In the new "Device Settings" tab I can either totally disable the touchpad or in "Settings", just disable the "TAP to click"; which is the feature causing the cursor to bounce all over.
Also in the active application section of the launch bar, lower right next to clock, an ICON is now present and "TAP to click" is an option, which I can now easily inable/disable; after opening the ICON with a click.
As I understand it, R46325.EXE is the R49155.EXE on steroids, but did not need that.
Posted on May 07, 2009
2 Suggested Answers
SOURCE: change touchpad settings for dell
Try going to Dell's site and downloading the application and reinstalling. This will add an additional tab to your mouse adjustments. It also gives you the option of a taskbar icon.
Posted on Apr 09, 2009
Why is my Cursor not moving dell latitude
  1. Click Start.
  2. Click Control Panel.
  3. Using the drop-down menu next to View by: in the upper-right corner, select Large Icons.
  4. Click Mouse.
  5. Click the Dell Touchpad or Device Settings tab.
    • When the Dell Touchpad tab option shows.
      1. Click on the picture of the touchpad.
      2. Click Gestures Settings (depending on your computer there may not be a gestures option).
      3. After changing the options click OK.
    • When the Device Settings tab option shows.
      1. Click the < + > next to open the options you want to change.
      2. After changing the options click OK.
Aug 17, 2014 | Dell LATITUDE Computers & Internet
Online users manual for model C640 PP01Ldell
You can download the online Service Manual for the Dell C640 PP01L Computer from the below link:
Hope this helps.
Jul 07, 2010 | Dell Latitude C640 Notebook
Our touchpad is not responding to tapping. It
Go into the BIOS (F2). Press Alt-P until you reach "Page 4 of 7". Under "Pointing Device" change the setting from "PS/2-Touchpad" to "PS/2". Reboot.
The touchpad and point stick will still function as long as there isn't a mouse plugged into the PS/2 port. If the mouse is plugged in, it will override the integrated devices.
Sep 23, 2009 | Dell Latitude C640 Notebook
I changed my Cmos battery & my laptop would not start after tha
Without battery, BIOS just gets reset to default and should not effect boot. There is a possibility that you failed to reconnect something important when disassembling the unit.
What exactly happens when the unit turns on?
Jun 18, 2009 | Dell Latitude C640 Notebook
Unlock password protected Dell C640
If it is a passwd set in the bios...good luck. You may have to download a disc from
If it is a windows passwd after the dell splach screen tap F8 this brings up the Advanced Startup Menu. Select safe mode and log in as the administrator. From there you can remove or change the password for all accounts. If there was never an account setup on that laptop and the Administrator account is being used then you will need a disk fron to retrieve that password.
Mar 22, 2009 | Dell Latitude C640 Notebook
Change touchpad settings for dell C640 laptop
Jul 01, 2008 | Computers & Internet
Mouse touchpad, keyboard, and usb drives will not work
One thing you can try (for the touchpad)
Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
Hope that helps for your touchpad
May 05, 2008 | Acer Aspire 3000 Notebook
Dell c640 wireless connectivity problem
That's gonna be a permissions problem in the way the wireless device was set up originally. Go to network devices, properties (of the wireless connection) and check advanced options for permissions. Also check the way the firewall was set up, and if it allows the connection you are requiring.
Good luck
Nov 17, 2007 | Dell Latitude C640 Notebook
Dell Latitude C640 Laptop
get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system changes then exit.
ps: defected processor could be the cause
Nov 14, 2007 | Dell Latitude C640 Notebook
Computers & Internet Logo
343 people viewed this question
David Payne
David Payne
