Question about Emerson EWF2704 TV
Emerson tv input problem
Hey i have the same problem with my emerson tv i lost my remote and universal remotes wont work how can i get my emerson tv to go back to input without the remote there is no options on the actual tv?
  • ramos924 Nov 09, 2008
    my emerson remote wont turn emerson tv on or off. this started suddenly last week. tried new batteries, universal remote, no help. I have DirecTv receiver and dvd hooked up also. I had no problems until now. any suggestions?
5 Suggested Answers
jmeredith
  • 417 Answers
SOURCE: lost remote
hi,
did you try channelling up- down all the way? is there a menu button on the front? if there is you might be able to using the menu buttons and the chan up down or vol up down to navigate, if that doesent work then yes probably have to get a universal. any newer universal remote should unlock it. Newer directv universals will work for sure..
J
Posted on Jul 11, 2008
mie999s
  • 105 Answers
SOURCE: lost remote and cant find code for universal remote
146 or 155 try ok
Posted on Jun 07, 2009
  • 7993 Answers
SOURCE: universal remotes won't work for Emerson 20'' CR2020EM9
It might be less costly to go to the Emerson web site, locate your model and check what remote control it answers to. Then buy the specific one.You can also go to a store that sells the particular model, take the refrences for the remote (model and Part number) and order it.
One thing though: It seems strange that a remote control made by Emerson, for a TV made by Emerson, cannnot, cannot activate an Emerson TV. Could it be a manipulation error? Just a thought.
Hope it helps.
Posted on Sep 07, 2009
  • 5 Answers
SOURCE: lost remote control for an emerson tv. how do you
I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote.
Posted on Dec 08, 2009
  • 8457 Answers
SOURCE: Emerson TV input option
Tries the channels + or - buttons a couples times on the tv manual controls buttons on the tv.U will get in the input option.This solution work for many tvs don't the input option on their universal remotes,without the original remotes.Ur tv don't know.
Posted on Jun 02, 2010
Lost remote will universal remote work
Universal remote codes for Emerson Brand TVs are: 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 Buy one universal remote control, which have these setup codes with its attached code list. Such remote controls will work with this TV.
Oct 26, 2012 | Emerson SpongeBob SquarePants TV
Jun 02, 2010 | Emerson EWF2704 TV
Lost sponge bob tv remote control
Get the RCA 4 device universal remote from radio shack. model #RCR4383N $10.00. It wouldn't work using the emerson codes in the manual. Let it find the code automatically. input button on bottom will switch to and from AV input.
Oct 10, 2009 | Emerson SpongeBob SquarePants TV
Universal remotes won't work for Emerson 20'' CR2020EM9
Hope it helps.
Sep 07, 2009 | Emerson Televison & Video
Lost remote control for an emerson tv. how do you change input from channel to video without the remote?
Jun 17, 2009 | Emerson EWF2006 TV
Lost remote
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote. Another reply mentioned using a duraband model instead of Emerson and it worked for him.
Apr 20, 2009 | Emerson EWF2006 TV
Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
Feb 11, 2009 | Emerson EWF2703 27" TV
Lost remote
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one...The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
A disappointing TV to say the least.
Feb 11, 2009 | Emerson SpongeBob SquarePants TV
LOST REMOTE
found a remote that works at radio shack. RCA 4 device remote model #RCR4383N. I first tried to manually enter the emerson codes but they didn't work. Used the automatic code search and it was working within minutes. The input-tv/vcr button on the bottom right of remote switches between AV and coax like it should...$10.00
Aug 02, 2007 | Emerson SpongeBob SquarePants TV
Emerson EWF2704 TV Logo
906 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
