Question about Canon Office Equipment & Supplies
Magenta ink ran out,continued to use printer,replaced ink tank twice,have done cleaning & deep cleaning several times no magenta coming through,all other colours ok. what to do next?? anybody have any idea's
Think you may have killed your print head, but try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Posted on Jul 03, 2008
Suddenly no ink coming from five wells (BK, R, G,
I have the same problem but it's only with the black ink, I removed the print head unit and run it under the hot tap till th ewater ran clear, then i soaked it in hot water and again run fresh water through it till it ran clear then left it in a bath of alcohol, i just used whiskey, but wouldn't recommend drinking it after, or before for that matter, I felt there was nothing to lose if it was a faulty print head as they are about £95 new. I had already run several deep cleaning programs and replaced the inks, but literally no black ink at all was printing. I havn'e tried it yet as it's still soaking, but I have also stripped the cover off the priinter and am trying to clean otu the waste ink tanks and absorbant pads, it's far to expensive a printer to just chuck out so here's hoping
Brian.
Jul 23, 2010 | Canon i9950 InkJet Printer
Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Mar 11, 2010 | Canon PIXMA MX850 Multifunction Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
Nozzle Still Clogged After Following Maintenance Procedures
just wipe the nozzles or the printhead .on a wet cloth...using DI(deionize water) to remove the clogs that cover nozzles...and then deep clean the printhead using the printer panel features...
good luck..
May 26, 2009 | Canon PIXMA MP830 All-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
My Canon i860 is not printing magenta. I run all the maintenace functions -- nozzle check pattern, print head alignment, cleaning, and deep cleaning -- twice. Problem persists. The magenta ink tank is...
If everything is clean and working fine then you need to first replace the ink tank and then check.
Also check if its happenning with eery application or some specific applicaion like MS WORD or MS POWERPOINT.
Thanks
Nov 14, 2008 | Office Equipment & Supplies
I960 canon printer
Lift lid ,let carriage stop in middle, un-plug the printer > Remove all ink tanks > Remove print head > Soak print head in > 3 parts very warm water an 1 part ammonia over night. Rinse under faucet with water directly over ink ports, shake out excess water,(if when you shake it out and if color still comes out repeat soaking for another hour or two and rinsing again ,HAD TO DO MINE TWICE) let air dry. (hair drier helps) Cured my problem for a while ,but if not used almost every day, this will happen again, I also use compatible ink tanks. Don'T believe the inks are as good as Canon Ink. But who the hell can afford them. So fill your owe with Canon ink from Canon. Still seems that the cyan always dries up first. Good luck Lestero1
Oct 18, 2007 | Cannon Canon i960 Photo Printer
164 people viewed this question
old marine
old marine
