Question about Dryers
Maytag front loading gas dryer
May tag dryer is 10+ years old and has developed this sound in the drum that sounds as though the belts that drives it is slipping. Is this a common problem with these units and if so, can an amateur fix it or would it be less expensive to find a fairly new unit on crag's list.
  • 246 Answers
Usually when it sounds like that it is because the one of the wheels involved with movment (support rollers or tensioner pulley) has started to wear down or has build up in side of it. I don't know what specific model you have, but this is a tear down and replace for these parts on a generic maytag frontload dryer. (elec or gas makes no difference in this procedure).First unplug the unit. Remove the front panel by removing the 4 phillips
screws just inside the door (on the hinges and just opposite). Next remove the greenish/ brown 5/16 screws that hold the front panel in. There are wires still connected (door switch and moisture sensor) but if you swing it to the side, you can leave them connected and still procede. Next, you have to reach underneath (very difficult to see this so you will have to do it by feel) There is a belt that wraps around the drum. On the underneath side of the drum as you follow the belt it wraps
around the motor pulley (small wheel) and the tensioner pulley (bigger wheel just to the right). Now with one hand, move the larger pulley towards the msaller one. This will give you slack and you can take the belt off both pulleys. Now pull the drum
forward. There you have the inner workings left. Now, there are 3 wheels. 2 black and 1 white. Your squeeking noise will be coming from the one that doesn't turn freely. You can get the replacement wheel from your local appliance parts store or on line from the manufatrues web site. However, if you do have to wait for the part, take the wheel off the shaft and wipe off the inside race of the wheel and the shaft for temporarily relife and useage.
Posted on Jul 01, 2008
Drum making noise
Hello Jodi Roberts. I want to help you with your problem but I will need a little more information please.
Can you describe the noise? Is it a vibrating type noise or Is it a squealing sound, as though the belt is slipping? Can you smell something from the dryer similar to the smell of burning rubber?
Dependent upon what you describe can tell me if it is the rollers or glides in the front of the drum support; OR rollers or bearings in the rear of the drum.
Or as I said before, a slipping belt from either a seized bearing on the drive pulley, or the idler tension pulley, or simply a worn & frayed belt that just needs to be replaced due normal wear & tear.
Thank-you.
Dec 04, 2013 | Maytag MEDX500XL Bravos X Front Load...
My maytag dryer is only 8 years old ,it ran for 10 minutes and stopped running, checked the breaker not that checked the plug not that what could have happened?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley, or a faulty motor.
If you have to check/replace/repair your drum motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Sep 23, 2010 | Maytag PYE2300AY Electric Dryer
Kenmore gas dryer won't turn
It sounds like the belt is stretched or slipping. The belt needs to be replaced. It has been a few years, but dryer cabinets haven't changed that much.First, unplug the dryer from the electical outlet. If the lint filter slides out the top, then remove the two screws that you see in that top door. Pop the two front clips and open the top like a clamshell. You should be able to see where the belt goes around the drum. The front is held on by a couple of bolts at the top of each side. If you remove them the front will swing out, but be careful with the door switch wires. Before removing the old belt, pay attention how it goes around the motor tension pulleys. Slide the old belt off and slide the new one on. Reassemble. I hope this helps
Mar 28, 2010 | Kenmore Dryers
My Maytag Dryer has developed a winding noise when turned on
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, Or the belt is maybe slipping on the drum
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers. Check your drum belt at this time.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 18, 2009 | Maytag Dryers
My Maytag dryer is 14 years old. Now it makes a
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Yes, replacing the drum rollers is fairly cheap especially if you do it yourself, saves you the price of a new dryer for a few more years maybe.
Good Luck,
I hope this helps
Oct 08, 2009 | Maytag Dryers
My maytag dryer makes an obscene rumbling noise every 10 seconds. It's still running and the heat works, but it sounds like it is about to shake itself apart.
I have not heard it call obscene but your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Good Luck,
I hope this helps
Oct 07, 2009 | Maytag Dryers
Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Aug 16, 2009 | Maytag Dryers
Dryer noise
A drum support wheel bearing could need lubrication or be replaced.  Also some drum support wheels have a rubber coating that wears off causing misalignment and noise.  Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced.
Jun 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
GE Dryer (new) makes noise
few possibilities here,idle pulleys could be wearing,front drum guides could be wearing,back drum bearing,bit early for these problems though,but sometimes coins get lodged at the drum paddles inside located 120degrees apart which wouldnt be anything to worry about if you can verify this,hope this helps
May 12, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
