27 inch Mitsubishi tube TV
The TV is 27 inch diagonal.
Are you saying the cost of repair would be prohibitive?
mavasu
mavasu@comcast.net
  • 3,037 Answers
A tv that old isn't worth more than $100, The part could cost half of that or even more depending on the exact model, definitely not worth it. A tv that size is a decent price today, Just buy a tv that can get a digital signal and you will be set for next year with it. Let me know if you need anything else
Posted on Jul 01, 2008
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Philips 42PFL5332D/37 Black screen with sound and remote works
You just said it - no backlight, if so there are only two things that can cause this, it is the lamps in the panel or it is the lamp power supply. These tv's are board replacement only, if it is in warranty i would get it to an authorized service center asap. If it is the lights in the pannel the pannel it's self will have to be replaced, the backlight cannot be replaced seperately. If it is out of warranty and it is NOT the lights in the panel the board ad labor will cost you a couple hundered dollars to fix. If it is the pannel the cost will be prohibitive to fix even if you were to change the pannel yourself.
Sep 01, 2009 | Televison & Video
How many inches is my ts2750j
27 inch measured diagonally (screen only and does not count the size of the cabinet)
Mar 12, 2009 | Jensen TS2750J TV
TV has no sound
basically your audio circuitry has failed then, and I wouldn't recommend replacing it unless you really want to or depending on the size of the tv for sure.
Jun 30, 2008 | Televison & Video
23 inch diagonal tv/dvd combination model # 23hlv87
with comcast red ok select switch 11256, 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast grey ok select switch 0154, 0156, 0060
May 20, 2008 | Toshiba 23HLV87 23 in. LCD Television
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
65 inch Mitsubishi tv Model # vs-60703
so does it have sound??? If so then the set is probably in a hv shutdown because of a weak tube or is in vieo safty mode as the vert has failed in the set. On cost here in Michigan a tube could cost up to 300 bucks + labor and on the vert repair about 250.00 to 400.00 to fix
Mar 30, 2006 | Mitsubishi VS-60703 60" Rear Projection...
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
