Question about Dryers
Replace dryer ignitor - Dryers
  • 1 more comment
  • Anonymous Dec 20, 2008
    my dryer has a serial # 10616192YF where can i find the igniter and how do i replace it?
  • Anonymous Apr 24, 2009
    how do you get to the ignitor for rr. Whirlpool model LGT6638ANO
  • Toby Norton
    Toby Norton May 11, 2010
    What is your model number (just inside the dryer door). For most of them, you unplug the dryer, open the door. Take out the two screws from the hinges and the 2 screws straight across from them. This lets your front panel come down and typically you can reach the burner assembly on the lower right hand side once the front panel is off. The ignitor will be the white ceramic peice on there.
  • 246 Answers
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Posted on Jul 09, 2008
Heat won't go on...don't know if it's an ignitor problem, or a coil problem
UNPLUG DRYER REMOVE TWO PHILLIPS SCREWS UNDER FILTER ON TOP LID ....
FLIP TOP TOWARDS WALL REMVOVE 5/16 SCREWS IN TOP CORNER OF CABINET AN LEAVE DOOR AND FRONT CONNECTED REMOVE DRUM BT RELIEV IDLER BELT TENSIONER INFRONT OF MOTOR AND SLIDE BELT AND DRUM OUT OF CABINET AND SET OUT OF WAY TURN DRYER IN TIMED DRYER NEAR 60 AND LAY ON FLOOR INFRONT OF DRYER ON FLOOR INFRONT OF DRYER INFRONT OF BURNER TUBE AND WATCH AND LISTEN IGNITOR SHOULD GLOW RED THEN A CLICK THEN IGNITOR SHOULD LIGHT GAS ..... IGNITOR DOSENT GLOW CHECK WHITE PLASTIC FUSE ... IF IGNITOR GLOWS AND NO CLICK THE REPLACE FLAME SWITCH ALUMINUM AND BLACK BOX ON LEFT SIDE OF BURNER TUBE ...IF CLICKS AND NO GAS REPLACE GAS COILS
Jan 26, 2011 | Estate TEDX640JQ Electric Dryer
The dryer spins but the burner does not always ignite.
Hi the most likely cause for this is a weak or failing ignitor. Remove the bottom front panel and observe with dryer running. If ignitor does not glow test it for 120vac if you have 120vac replace ignitor. If it glows but does not ignite the you ignitor is weak replace it.
Nov 03, 2010 | Kenmore Dryers
Dcvh515: dryer does not heat. Replaced the ignitor. Still no good
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 03, 2010 | GE DCVH515GF Gas Dryer
I replaced the igniter and thermal fuse and dryer
The thermal fuse should only be replaced if the dryer will not start
If it starts the thermal fuse is good.
If you touched the ignitor with your fingers it may have blown out.
Open the dryer and check for voltage to the ignitor through the ignitor wires while the dryer is on.
If you have no voltage check the hi-limit thermostat for continuity as well as the operating thermostat.
Check the flame sensor for continuity while it is cold.
If you have power to the ignitor place a clamp on amp meter on one ignitor wire and turn the dryer on.
If you read 3 amps or less the ignitor is bad.
If it reads the amps or more the gas valve coils are bad.
Jan 17, 2010 | Whirlpool Dryers
Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Jan 12, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Not heating up Gas Dryer
Modern gas dryers do not have a pilot light. They have an electronic ignitor (glow or spark). A glow ignitor turns on several seconds before the gas turns on and should get orange hot. A spark ignitor should make a clicking or buzzing noise.
Most likely the ignitor is bad but you can check it fairly easily to make certain. The best instructions I have found are at
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
If it is the ignitor it can be replaced with a few hand tools. Remove the bad ignitor. Write down the make, model, and serial # of your dryer. Call your local appliance parts store to see if they have one it stock before driving over there.
Dec 22, 2009 | Whirlpool Dryers
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Gas dryer ignitor not activating
You have to use a voltmeter to test the circuit. You must connect a voltmeter to the leads that go to the ignitor, and then start the dryer. If the ignitor is getting 120 volts, but not lighting, then you need a new ignitor.
If you do not feel comfortable doing this test, you could simply replace the ignitor and hope its the problem
Jun 10, 2009 | Kenmore 63942 Dryer
How do i change the ignitor in my dryer
First, why do you think ignitor. In all the dryers I fix only 1 dryer in 999 need the ignitor replaced.... Hit me back before midnight for more help........
Dec 12, 2007 | Kenmore 74832 Gas Dryer
Dryers Logo
396 people viewed this question
Top Dryers Experts
