Question about Gateway 400SD4 Notebook
Gateway 400SD4 Power Problem
With AC adapter plugged in LED light shows battery charging - will boot into Windows for a few seconds then goes into Standby Mode. Turning off standby mode screen will sometimes have vertical green lines then back to Standby mode. W/out AC adapter plugged in LED light shows battery malfunctioning.
  • 1 more comment
  • Anonymous Sep 25, 2008
    instant turn off
  • ebgwd Feb 26, 2009
    My Gateway was under 3 year warranty but Gateway sold the warranty to a company that went bankrupt so I am stuck holding a broke Gateway, under warranty. I replaced the AC plug in the back and now the Gateway laptop works but when it boots into XP it shuts down after 2 seconds of starting XP loading. I put the battery into test using F2 and it ran the battery test (2hour test) and recalibrated based on battery test. I can sit on F2 bios config screen for hours just fine and not error is logged in the bios event log. It will not load XPpro and crank up. Just down powers the laptop each time I try. Tried booting from CD and it powers down before spinning and reading the CD.
  • Anonymous Mar 31, 2014
    When I plug in toshiba with charger, the green and orange light sometimes come on for a few seconds, then go out. Have also gotten the net book center button to light up one second and then go out. After having had the charger plugged in awhile. The netbook does not boot....is completely drained.
    Problem Solver:
  • 13 Answers
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Posted on Jul 01, 2008
Laptop will not power on. light will come on for about 1 sec.. ??
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe you have a bad memory chip.
Remove the Power Cord, Remove the battery, remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 18, 2012 | Gateway Computers & Internet
Laptop Power Up Problem
Try booting under AC power with the battery removed.
Jun 05, 2008 | Gateway 400SD4 Notebook
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Have a Gateway NV78 Laptop love it but there are 2 blue lights on lower left corner of the laptop and the one on the right goes to "red" sometimes why? This is "on the case" not the screen/monitor...
Do you have the Gateway NV78 Series User's Reference Guide?
(English)
Gateway Support > NV78 Gateway NV78 Notebook Series > Support Documents,
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78ul.shtml
If not, left-click on,
Gateway NV78 Series User's Reference Guide - English
This is a PDF file.
Takes a few seconds before you see the first page, and additional time to fully download.
Suggestion is that you let the file fully download, before looking through it.
(Your computer has Adobe Reader on it, which uses PDF files)
Page 18,
Battery Charge Indicator.
(Has a symbol which looks like a flashlight battery)
"LED Solid Red
Battery is malfunctioning
Important: This LED only lights up when your notebook is connected to AC power, (The AC adapter is plugged in. 'Charger'),
or the battery charge is very low"
Jul 03, 2010 | Computers & Internet
Gateway MA7 (MX6955) Will not boot up, or power on. Battery and AC plugged in battery LED light flashes 4 times and nothing... battery in AC unplugged.. same thing... battery out, AC plugged in.. nothing,...
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
Oct 08, 2009 | Computers & Internet
Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Feb 05, 2009 | Gateway Computers & Internet
Gateway 400SD4 won't power up
replace the battery or have it tested. If these batteries don't have a minimum charge the machine will not boot into windows & will just shut down.You might try checking the battery condition with the "battery conditioner" in the bios
Rockman
Nov 26, 2008 | Gateway 400SD4 Notebook
Gateway 400sd4
You should try plugging in an external CRT or LCD monitor. Most laptops will automatically enable this port when you connect a monitor and reboot, but you may need to hit some combination of keys on the laptop if you don't see anything.
You should try this to see if the laptop is running properly other than the internal LCD or VGA hardware.
Dec 16, 2007 | Gateway 400SD4 Notebook
Power
Try this:
With the AC adapter and battery installed and it will not power up remove the adapter and the battery. Then plug in the
AC adapter after both have been removed for 30 seconds and let the laptop set for 30 seconds and then unplug the AC adapter and then slide in the batter within 15 seconds and try to start the laptop.
Nov 24, 2007 | Compaq Presario 900 /1500 Series EVO...
Gateway 400SD4 Notebook Logo
321 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
