Question about Photography
Nikkormat Took the old camera out yesterday, and we pushed the timer down, and the shutter button. Now neither is doing anything. Thanks
  • stonemea Jul 01, 2008
    Nikkormat FS
    Habit-Forming:
  • 178 Answers
This is one of the `good old uns` the most likely cause the timer has jammed from not being used not much you can do without a strip down.if your in the UK send me an email and will repair for you.SUPER8.
Posted on Aug 04, 2008
SOURCE:
My Vivitar takes blurry pictures. Kindly show me what to do to sharpen the focus. Thanks.
To focus on your subject, lightly push the shutter button (the button you use to take pictures) only half way down. When you push the shutter button half way down, this auto-focuses the camera and you can then fully press the shutter button to take your picture.
Sep 01, 2011 | Vivitar Vivicam 8225 Digital Camera
Nikkormat 35mm SLR light meter not working!
1) Clean the battery contacts and put fresh battery.
2) Open the top cover and clean the meter switch ( located and the wind cam )
3) Meter needle maybe stuck at the rest position. Remove the stopper and replace or clean.
4) If none of these help, check the meter cells and resistor band under the shutter dial behind the lens mount ( hard to do.)
Jun 14, 2010 | Nikon Photography
How do you use the self-timer on my the nikon coolpix?
On your menu navigation buttons, push the left arrow to get to the timer. Then push up or down to turn the timer on. Then push the middle button to exit. Now position the camera for the picture, and push the shutter button. You will have I think about 10 seconds to position the subject. It's a cool function, have fun with it!
Apr 05, 2010 | Nikon Coolpix 3200 Digital Camera
I want to have the camera take a pic of my family on its own
Yes. You can even choose between 2 seconds and 10 seconds. Put the people in the shot. Focus the camera on them by holding the shutter button down halfway, and without releasing the shutter button, press the button all the way down to start the self-timer. (That's what the manual says. I go into the menu on the camera and set it up that way.) To do it from the menu: when the camera is on, hit the menu/ok key. The self-timer mode will pop up. Hit the right arrow. Here you can choose between the 2 and 10 second timer options. Select one. The timer won't start until you have pressed the shutter button halfway to focus and press the shutter button all the way down as stated earlier.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Film advance lever wont move. Shutter button does not register.
the self timer may be the issue. the self timer if not all the way released will not allow you to advance to the next frame :( i sometimes have to push it back to the start position
Nov 13, 2008 | Photography
Camedia C-5050 zoom won't take pics
Is your memory full? Does the camera attampt to focus when you push the button down 1/2 way? If not the mode dial may be faulty (you are not in picture taking mode) or the shutter button may be faulty (no focus attempt) Try to use the timer button to get the shutter to trip.
Jul 10, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Nikkormat FT
I have a Nikkormat FT, and I can assure you that there is no "timer" button on this camera. There is, however, a timer lever to the left of the lens if you are looking at the front of the camera. As for the light meter, have you tried moving the film advance lever to the "cocked" position, since that turns on the meter.
Jul 01, 2008 | Nikon Nikomat FT 35mm SLR Camera
D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Feb 03, 2007 | Nikon D50 Digital Camera
Photography Logo
Top Photography Experts
Steve Allison
Steve Allison
Ric Donato
Are you a Photography Expert? Answer questions, earn points and help others
