Question about Casio G-Shock G7000D-8V Wrist Watch
Wrist band adjustment
Hi. I just bought a Casio global atomic solar pathfinder with a titanium band. I figured out how to remove the pins in the band to remove links in the band, but when I try to replace them they fall right out. Any ideas?
In addition to the Pin there is also a small inner "locking" collar about 2mm long that fits into the center section of each link.
I did not notice this collar at first and it fell to the ground when I removed the first link. Without this piece the Pin's will just slide through the links with no locking mechanism.
It fits neatly into the inner portion of the link directly opposite the arrow that shows the direction of removal on the band.
Posted on Dec 06, 2008
I just bought my casio pathfinder paw 1100 wsatch and my alt and baro doesnt look like is working
http://world.casio.com/wat/download/en/manual/
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
May 07, 2010 | Casio PATHFINDER ATOMIC SOLAR WATCH...
How do you adjust the band?
Read my tips and tricks. Watch band is called bracelet as well.
Jan 23, 2010 | Casio Wave Ceptor Atomic WV300DA 7A...
Replacing watch band on pathfinder pas410. can't get pins out to replace band.
Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
Rate me, plz.
Jan 08, 2010 | Casio Pathfinder PAS410B5V Wrist Watch
How to adjust the band on a GW800D Tough Solar
By finding a spring loaded rod in the clasp (that is in the set of three holes in the clasp) moving it to the last position. However it was still loose, so by finding the spring loaded rods that hold the links of the band together, pushing them down in the direction of the arrows and removing enough links to fit.
Aug 29, 2009 | Casio GW800D 1V G Shock Atomic Solar Watch
How do I get the pins out of the titanium band for Casio PAW1500T
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Jul 09, 2009 | Casio PAW1500T-7V Atomic Solar Pathfinder...
How do i put on the wave ceptor ?
This depends on what you mean by your question.
To adjust the size of the band, if you look on the inside of the links (the side that goes against your wrist), you will find that at each link joint, there is a spring-pin (like the traditional pins for attaching bands to watches) which can be easily removed.  Remove the necessary number of links to size the band to your wrist.
To put the watch on your wrist, merely position it as desired, and, close the clasp by grasping the outer buckle with your fingers, placing your thumb against the mid-segment, and squeezing the two together. Then, move that assemblage upwards toward your wrist.  Move your thumb out of the way as it approaches closure and push it together until the outer buckle clasp clicks into place around the stud on the inner segment.
If you are asking how to get the watch to receive the time from WWVB, this will happen automatically once per day (three attempts per day until one is successful).  If you want to manually trigger an attempt, this can be accomplished by holding the "RECEIVE" button for a few seconds until the watch beeps and the display reads "RC!".  It will then attempt to receive the signal from WWVB for several minutes and calibrate if successful.
You can identify whether the last synchronization attempt was successful or not by the display in the lower right corner while the time is displayed.  It will show an antenna and three bar-graph segments if it was successful, or, be blank if it was unsuccessful.
If you mean something else by "put on the waveceptor", I'm afraid I don't understand your question.
Mar 10, 2009 | Casio Atomic-Solar MTG900 Watch
Casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Dec 17, 2006 | Casio G-Shock G7000D-8V Wrist Watch
Casio G-Shock G7000D-8V Wrist Watch Logo
1,138 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
