Question about Ariston Technologies AWD121WH
Ariston AVXL129 7.5 kg frontloader/two years old
The rubber bellows(seal) between the door and the bowl has black (mould?) marks all over. I cannot seem to clean these off, have tried various household solutions but no luck. Can anyone suggest a solution.Thankyou
5 Suggested Answers
  • 1462 Answers
SOURCE: Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
Posted on Mar 31, 2007
SOURCE: Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
Ariston "Margarita 2000 cpu map photo
Posted on Nov 20, 2009
SOURCE: replacing a rubber door seal on washer machine
1. Remove door (2 screws).
2. remove top (2 screws at back, sharp slap to front to dislodge).
3. Remove 2 screws holding powder dispenser to inlet valve.
4. Remove 2 screws at front corners securing fascia.
5. Remove fascia and powder dispenser as a unit - note plastic locating pegs on underside and plastic clips locating bottom onto front panel. Take care not to drop one of the rubber seals from valve/powder dispenser joint. Do not disconnect the wiring, just lay the complete assembly on top of the machine.
6. At some point, you will need to release the retaining wire securing the seal to the front panel. This is a thin spring loaded wire. Look after it, you will need it again.
7. Remove two screws at front securing front panel.
8. Remove kick panel - this allows access to two more screws securing bottom of front panel - take these out as well.
9. unclip the wire connector to the door switch.
The front panel may now be lifted from its plastic retainers.
10. The second wire clip can now be removed. The clever clip will need to be released to allow refitting.
11. Thoroughly clean and disinfect the seating for the new seal - you don't want the same gunk growing into the new one straight away.
12. On the drum, you will notice a protruding moulding at about 5 o'clock. There is a matching flange on the seal to help you locate it accurately - start here and fit the seal.
13. Fit the wire retainer - you will need a good pair of long-nose pliers to retension the wire.
14. Reassemble the machine in the reverse order - take care not to mix up the screws! remember to fit the seal to the front panel before refitting the door. Do not release the spring from the wire, carefully stretch it into place.
Posted on Jan 03, 2010
dcramer531
  • 1654 Answers
SOURCE: I have front loader washing machine and the rubber
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Posted on Apr 08, 2011
    How do i clean Bosch WAE20261AU front loader washing machine
    The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
    Apr 27, 2013 | Washing Machines
    How to remove black mould from rubber door seal
    the best thing to do is replace the rubber boot.
    Mar 19, 2011 | Washing Machines
    Mould/gunk on the rubber seal of a Maytag MAF1300 AAW - help!
    Once mold is present the only way to get rid of it is with peroxide. Any residue left will grow again.
    May 13, 2010 | Washing Machines
    Hello, our miele w5040 is about 6 years old and we
    if you mostly use lower temperature washes a bacterial mould builds up inside the machine. it can be seen as a black residue in the soap dispenser drawer and in the folds of the rubber door seal. a grey sludge also builds up on the inside of the wash drum and the drain filter. doing at least one hot wash ( above 60 C ) a week can stop this happening.
    Aug 26, 2009 | Washing Machines
    Is there a way to clean rubber seal around the opening?
    Use a vinagar solution to clean the rubber seal. bleach will damage the rubber.
    Apr 29, 2009 | Washing Machines
    Black marks all over the rubber seal at the front of machine.
    The mould you are referrng to is actually bacteria that is building up because you are doing too many low temp washes.
    What you must do is a high temp wash periodically,with powder in but no washing.
    Do this 3 or 4 times a year, more if you do a lot of wahing.
    It is called a maintenance wash, and helps kill off the bacteria.
    With a scouring pad or steel wool pad, clean as much scum as you can off the door seal. particularly in the folds of the seal.
    You will probably be left with stains in the rubber, but as long as you have got the worst off, it should be o/k.
    Please rate my solution.
    Thanks.
    Jan 21, 2009 | Hotpoint Aquarius WF000 Front Load Washer
    Stains on clothing
    Usually black oily stains are a symptom of a rear main drum bearing starting to go bad. The seal goes bad first and the packing grease will start to weep out as water gets into the bearings. Is the washer starting to get loud during any spin cycle? If so, I think your bearing is starting to go. It's not a cheap fix, either. The whole back shell of the outer wash tub has to be replaced because the bearings are molded into the plastic. I hope this is helpful in some way.
    Jun 11, 2007 | Kenmore 43052 Front Load Washer
    Ariston Technologies AWD121WH Logo
    61 people viewed this question
    Top Ariston Technologies Washing Machines Experts
    Darren Moxam
    Darren Moxam
    Gerry Harvey
    Gerry Harvey
    Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
