Question about Dell Inspiron 2200 Notebook
Cd rom problems
I have a dell inspiron 2200. the cd drive will not play any type of cd. i checked the device manager and it indicates that it is working correctly. i think that the drivers are corrupted. any suggestions?
    Genius:
  • 2,028 Answers
I just replaced the CD drive in my 2200, the eye went out. You can check to see if it's the drive or drivers by uninstalling the drivers from the device manager, then reboot. It will find the drive and reinstall the drivers. If this doesn't fix it, then the drive is bad. The drivers for optical drives are very simlpe, some times they will glitch and need to be reinstalled, but most of the time it's the drive that has gone out.
Posted on Jul 01, 2008
My cd drive will read cds but wont read as a burner
Not all Inspirons have CD burners (the 4 factory options were CD-ROM, CD-RW, DVD-ROM, and DVD/CD-RW. You can confirm that via Windows Start > Control Panel > System > Hardware > Device Manager and double click on DVD/CD-ROM drives to see what model drive you have, then just Google it to see what it's capable of.
In case you have either a CD-RW type drive or a DVD/ CD-RW drive and it doesn't want to burn CD's , then it's a bad drive.
Sep 08, 2011 | Dell Inspiron 1100 Notebook
Dell Inspiron 1501 CD-Rom wont play.I can hear it start to spin.Can play stored music.Have no CD Rom or filters showing under "Device manager".
If the CD-ROM drive is not being detected under the device manager, chances are that either the power/data cable is loose or the drive is dying. To check the cables, turn off the power, unplug the power cord, open the case and examine the two plugs behind the drive. Touch yourself to something metal first to discharge static electricity.
If it turns out the drive is dead, then luckily drives are usually very cheap to replace. Somewhere in the line of $15 usually.
Mar 07, 2011 | Dell (6T980-A01) CD-ROM Drive
My dvd rom on my Dell Inspiron 2200 is not working properly
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 14, 2010 | Dell Inspiron 2200 CD-RW/DVD Drive Combo -...
BOOTMGR is compressed everytime I start my DELL Inspiron 2200, what should I do
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type
compact /U C:\bootmgr
compact /U C:\ntldr
Jul 27, 2010 | Dell Inspiron 2200 Notebook
I have a dell inspiron 1440 laptop i got about 6 months ago and the cd/dvd drive stopped working. how do i fix this?
If there is an error code in Device Manager for the DVD and CD, try this:
Fix for missing DVD/CD drives.
Create a text file with NOTEPAD containing the following data exactly as below and name it FIXCD.REG
You should have 3 boxes on the bottom in NOTEPAD.
1)Filename : fixcd.reg
2)Save as type: all files
3)Encoding: ANSI
If you do not change it from txt type to All files type, then the file will actually be fixcd.reg.txt, this won't accomplish the desired result
Double click on the file and say yes to the merge into registry question.
----------------------- Use text after this line, contents of FIXCD.REG -----------------------------
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
"UpperFilters"=-
"LowerFilters"=-
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdr4_2K]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdralw2k]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdudf]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UdfReadr]
The original post get from: http://forums.techguy.org/hardware/525621-solved-dvd-cd-rom-drive.html and http://www.brand-new-battery.com
Jul 02, 2010 | Dell Inspiron 2200 Notebook
My cd rom wil not work it just quit working for no reason it will not play any cds or let me burn anything
First open the "Device Manager" to check for any error messages related to the device and click on "Start" and select "Control Panel" .
Now double-click on the "System" icon then click on the "Hardware" tab and click the "Device Manager" button. A new window appears, and displays whether the device is working properly. If there are any errors, click the "Troubleshoot" button and follow the given onscreen instructions.
Check the DVD that you are trying to use to and ensure that it is free of dirt and scratches and the proper format compatible with your drive.
Now uninstall any drivers that may be on your computer from previous DVD drives.
Now download the latest driver updates for your DVD drive model from Dell website & install it.
Also check on Dell website that your machine has the minimum requirements to operate the drive.
Now restart your computer & check your DVD drive.
I hope issue has been resolved.
If the same problem is still occurring, get the reliable Dell support at http:/www./vtechsquad.com/dell-support/
Nov 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell CD/DVD shows up in 'My Computer' but doesn't recognize CD's
the cd player could be bad it doesn't seem to be reading anything. or your windows needs reloading because you have other programs overwriting each other and windows.too much on the drive defrag it
Dec 27, 2008 | Dell Inspiron 2200 Notebook
Cd/dvd rom not working
go into device manager and see if your drive is listed or has an exclamation point beside it.if you dont know how to open device manger go to start menu and click help and search device manager.if there is an exclamation point ! click it and it will tell you the problem.you may need to download a new driver or reinstall the old driver. the only other possibility is the drive is dead :(
Nov 14, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 530 wont play DVD roms
try these steps:
1.Go to Start>Run and type regedit.Than go to HKEY_LOCAL_MACHINE>SYSTEM>CURRENT CONTROL SET>CONTROL>CLASS>{4D36E965-E325-11CE-BFC1-08002BE10318} and remove the upper and lower filter.
2.Go to start and right click on my computer and than click on manage.On this creen go to the option which says Device manager and look for the option for the cd drive.Expand it and than right click on the option it gives you and uninstall it.After that close everything and restart the system.
3.Also similar way you can remove the primery and secondry channels in the device manager.
Dec 22, 2007 | Dell DVD-rom DVD Drive
Dell Inspiron 2200 Notebook Logo
48 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
