Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover steam vac silver
The trigger that operates the shampoo to the carpet does not work. I have unscrewed the cover and found that the trigger is loose. Help...will this be an expensive repair? thanks much
  • 1,673 Answers
If the trigger is loose, then the part that it sits in(inside the handle) is broke, you will have to replace the handle asm. or maybe just the handle piece itself.
You order it here for $17.00+ s/h
Posted on Sep 01, 2008
Operationing instructions for hoover model fh50020rm carpet clearner
I have an Hoover Steam Vac Carpet Cleaner Model# FH50020RM, it's not working. The water is not coming out and not retracking the water.
Jun 05, 2011 | Hoover Vacuums
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Need instructions for filling the Hoover Steam Vac Spot with cleaning solutions
Hi There,
Here's a link to the owners manual for your Hoover F5505 Steam Cleaner that will explain step by step how you can add water & cleaning solutions and carpet shampoo. I hope that this was helpful to you. If it did help you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Hoover F5505 SteamVac Spot Vacuum Product Manual:
Thank you, this is really appreciated.
Chris J.
Apr 06, 2010 | Hoover F5505 SteamVac Spot Vacuum
Water and shampoo run out with the trigger in the off position
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Nov 30, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac model # f7441-980
Hoover steam vac
Posted by beverlyarm on Mar 21, 2008
XThis Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request By reddevil6, posted on May 01, 2008 What is your problem? Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You may have a bad water pump, bad gasket, the water release valve could be broken, or the water tank is not sitting on the opening properly or the trigger assm is not closing properly. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Mar 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My vacuum will not extract shampoo from the carpret
we found that there was a small slit in the hose assy and had to replace it.
Oct 09, 2007 | Hoover F5807 SteamVac Wet/Dry Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
276 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
