Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Battery installation instructions
I just bought a battery for my Black & Decker mower from batteries plus but it has been so long I do not recall how to install. I took picture with cell phone assembled but too blurry to see + and - terminals and do not want to hook up wrong any suggestions ?
    Champion:
  • 313 Answers
Color coding. red wire is for +. black wire is for - .
Posted on Jul 06, 2008
Putting new battery in black & decker cm500
there our three different battery for black and decker the batteries do not interchange you probably got the wrong battery are get the smaller battery black decker battery our maybe go battery plus they will get you the right battery
Apr 20, 2014 | Garden
Black & Decker CMM1000: The mower runs, but has no power
The battery is dying., need to be replaced. price is around $100.00 so be prepared to invest a couple of bucks. I believe there is an update "RECALL" on this units so you better call their customer service.
Sep 20, 2009 | Black & Decker Garden
Black & Decker Pivot Plus
this one dosn't charge. It takes batterys. how do i change them
Dec 20, 2008 | Black & Decker Pivot Plus Cordless...
Replacement batterys for cmm1200 black&decker electric mower I have a Stealth Black & Decker rechargable mower and would like to know what battery I need and can I replace it myself Thanks Cherie
I discuss the solution to your problem in my review. I am using a replacement AGM Lead Acid battery that increased my mowing distance and does not take more power to charge because the battery has an lower internal resistance. The battery is a Power Sonic, PSH-12180FR, 21Amp Hour unit. You will need to order two of them.
We should all do our part to save the enviroment and encourage the growth of the solar and wind power industries.
Cordless electric lawn mowers go a long ways towards these goals. I recently purchased the Black & Decker Cordless Electric Lawnmower the CMM1200.
In the review I describe how to upgrade the mower to mow over 9,000 SQFT!
I hope my review will help you make a decision about our future.
http://www.epinions.com/review/Black_Decker_19_In_24_Volt_Cordless_Mulching_Mower/content_445899312772
Sep 30, 2008 | Garden
B&d cmm1000
see if ur mower is cmm1000 type 1 to 4.this unit are recall for
board. see service center to upgrade the unit to CMM1200. if ur battery are not holding charge need the battery is not parts of the recall.battery will last 3 to 5 yrs apx.
Aug 15, 2008 | Black & Decker 19" Electric Lawnhog...
Rechargeable lawn mower lacks power even with replacement battery. Six or seven year old rechargeable Black and Decker 24 volt mower. Replaced the battery last year after it became unable to mow my...
just to let u know CMM1000 mower are on recall for pcboard.
if ur mower is type 1 to 4 then its the subject for recall for convertion to CMM1200.see ur nearest service center right away.
Aug 09, 2008 | Black & Decker 19" Electric Lawnhog...
I need to replace a battery in the Black & Decker CMM1000 cordless lawn mover but I can't find any directions. Can someone help me?
The battery in my CMM1000, purchased in 2003, finally gave up early in the summer of 2009. I bought a replacement battery at the local DeWalt store for about $140 including tax. The original battery was comprised of two Panasonic 12Volt, 20Amp-hour units in series. The replacement battery is comprised of two BR 12Volt, 17Amp-hour batteries in series. To replace the battery, simply remove two Torx screws toward the front on top of the black cover and two more, one on each side of the cover down next to the orange base toward the rear. It is not necessary to remove the two screws near the charge indicating meter. Cut the first two or three tiewraps holding the "throttle" cable to the push handle so as provide some slack. Lift the black cover up and over the height adjusting handle. Do that and everything else to be described here while working from the opposite side of the machine. The cover will not come all the way off and it is not necessary for it to do so. It will lift up far enough to allow removal of two pieces of styrofoam, one between the battery and the motor, the other between the battery and the inside rear of the housing, and the battery. The battery is held down by a fabric strap that is attached to the base of the machine with a screw on each side. Remove the one opposite the height adjuster. The battery will then be "loose" except for the two electrical wires that connect it to the machine. Lift and rotate the battery so as to present easy access to the terminals. I used my B&D drill motor with the appropriate socket to remove the flanged nuts retaining the cables. The battery can be removed from the machine once the cables are disconnected. Reverse the above procedures to install the new battery. Important note: The throttle cable has to go under the front styrofoam piece... the black cover will not go all the way down until the cable is in the right place. One might be tempted to push harder and that could lead to real trouble, so be sure the cable is under the styrofoam. The CMM1000 is an excellent machine in my opinion, and the ton or so that it weighs provides a good workout for me that I personally enjoy.
Jul 30, 2008 | Black & Decker 19" Electric Lawnhog...
B&D CMM1000 Mower
convert your mower to cmm1200. you needs parts 905058-81 to convert it.this to elliminate the circuit board & it's easy to install just follow the instruction. circuit board was on recall depend on the date code of the mower it is also no longer available.
good luck.
Jun 02, 2008 | Black & Decker 19" Electric Lawnhog...
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
62 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
