Indesit front loader washing machine model wi 121
While I was abroad, a couple of weeks ago someone used my washing machine and must have "forced" the front loading door to open with the result of wickening the system/spring? which allows the door to open... the machine washes great but the door will not open/is stuck... and I have a load in it... Not happy... but most of all need a bit of help if possible before I call a service man: I live in the country and it will not only take time (I have not got) and money (I have even less!) ANY IDEA HOW TO OPEN THE DOOR??? Kind regards Cecile: carsacbutefrog@hotmail.com
  • carsac Jul 01, 2008
    I have done what was suggested:start again a new cicle... but the door will not open in the end. the little "flap: behind the main handle of door is "soft" to the touch and does not allow the "click" required to open the door... what to do next. Regards cecile.
    Master:
  • 638 Answers
I will provide you the best link to help you to try your self before calling a service technician
it will help you to solve your problems with diagrams and step by step instructions.
www.repairclinic.com
you just have to place the arrow of your mouse on the parts and the names will appear and you can find how to fix your problem.
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
Posted on Jul 01, 2008
    Genius:
  • 2,035 Answers
The door seal is damaged which causing this problem, you need to replace the seal in order to open the door freely, you need to fix the seal in order open the door.............
Good luck...
  • 4,472 Answers
Get a thin piece of wire or string, feed it into the door and pull it back to unlock the door. (Hope you get what I'm trying to say here).
Once the door is open you'll be able to ascertain what parts are required to repair.
If your door handle is on the right, feed the wire from the right side of the door and work it until both ends are at the left side, then pull to the left.
Hope this helps and keep me updated.
Thanks,
Lee
  • 983 Answers
Lots of people force the door open out of frustration and cause extra expense. There are many reasons why the door may be jammed shut -
The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub. Water forces air up this tube and locks the door) Washing machine won't empty water
The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
Door interlock jammed
Door catch, handle, or mechanism broken
****** (a device that detects the motion of the drive belt fitted to many older Hotpoint washing machines which "pecks" at the belt when the door handle or button is operated) is broken or has fallen off
Do not take the lid off and reach inside the washing machine to try and release the door if the washing machine is still plugged in as you will be electrocuted.
Make sure the washing machine is unplugged if you keep messing with it.
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 01, 2008
    See if you can move the dial after you turn it back on
    try turning it on again and wash those clothes & then after the operation completes the door may open automatically
I have an indesit washing machine model WIA101 that needs draining in prep for disposal and i don;t know what to do
front loader direct drive
drop the drain hose to the ground let gravity empty the water
can be dumped as is
no oils or asbestos in its design
Jan 22, 2017 | Indesit Washing Machines
Indesit washing machine W1A 121 no red light when
Select reset from front panel and reset timer. you may needalso to cure water level fault as its overfilling. could be dirty air hose to pressure switch...
Nov 13, 2009 | Washing Machines
Indesit WIA 121 not working - door latch not shutting
At first thought it was door lock mechanism was at fault but proved it to be ok - removed rubber 'boot' which on this model was on two stretchable spring retainers and checked operation of door lock.
Thought door hinges may have been bent so dismantled door, finding the problem to be the pin that the door latch pivots on had come out on one side so not lining up properly. This was easily pushed back into position.
Oct 05, 2009 | Indesit W 123 Front Load Washer
I need a users manual for Indesit 657 W front loader
Click on Indesit(all products in blue) the click on your model number on this website, type in & search. You will get a shortlist; click on your model, below the page you will get Manual/Guides. Click on the blue, you have your manual on line. If available that is............
You could also search from "user manual" (blue) above.
Feb 23, 2009 | Indesit WA 125 Front Load Washer
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
Indesit WIA 121 washing machine, front loader. The door lock led is continuessly flashing red even when the programme has stopped and the door is opened. I have to switch off at the main plug. Machine is...
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Apr 21, 2008 | Washing Machines
Trouble with Indesit WI 102 washing machine
I had trhe same problem and was going deaf!!! I know this is probably too late for your machine but it may be usefull to someone else with this model.
Originally thought the bearings had gone but had great trouble trying to source some through UK websites so decided to strip the machine. Did this by touch (no manual!) and eventually found that the bolts holding the bottom weight to the drum had all come loose (all 3!). Trying to access them to tighten was the biggest problem as the front of the machine is welded on.
Managed the above by removing the rubber door seal from the door only and tightening two of the bolts from inside the door. The third I managed to access from beneath the machine. All were tightened using 10mm socket on a bar with extension (curtain pole!) slid over the end.
During this process I had the machine on its side, removed the securing brackets, top weight + springs and wedged the drum from beneath and the side as much towards the rear of the machine as possible to aid access.
Good Luck!
Mar 09, 2008 | Indesit Washing Machines
Indesit WI 121 washing machine
If this is a front loader it could be the up/down motion causing machine to vibrate against the floor. You can pick up some cushion pads for front load washer and dryers at the dealers to go under the four corners of the machines.
Dec 29, 2007 | Washing Machines
Washing machine
The knob keeps turning when you have a problem with the machine the most common problem with indesit is the pump. check to see if there is any thing in the filter compartmet located at the bottom on the front of the machine if so clean and replace.. THEN you will have to reset the knob. you do tis by turning the dial to one of the off position (the big black dot ). Then leave the door open and keep switching the machine on and off quickly from the button on the front of the machine untill you c the lights flicker rappidly.. once this happens the machine is reset and ready to wash ... p.s The pump can be one source for a problem... others include brushes on motor.....but most likely it will be the pump tell tell signs are water in the drum
Nov 20, 2007 | Washing Machines
Indesit wi 121
pull out the part you have been turning and it unscrews and the filter pulls out. it should not be smelly.if you are using liquid detergent, this will cause the smell. some water will come out when you remove filter but not huge amounts assuming the machune has drained properly
May 19, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
