Question about Kenmore 63952 Electric Dryer
Start Button will start dryer but won't stay on!
We have a Kenmore 63956 Dryer. When I press the Start Button the dryer comes on (and is tumbling) however, when I release my finger it shuts off!
I've checked to see if the dryer door is closed properly and tightly .. it appears it is. The sensor in the door is working.
Help!
Thanks!
Lisa
  • 1 more comment
  • Lisa Chakford
    Lisa Chakford Jul 01, 2008
    oldfixer! You Rock!
    We did exactly as you mentioned... the problem is the control bd! We took it out and we're working on ordering a new one!
    Thanks so much!
    You certainly made our day :)
    Lisa
  • Anonymous Jul 11, 2008
    Where can I get a new board?
  • mattshari Feb 21, 2009
    Push in the start button and the drum starts rolling, but as soon as you remove your finger from the button, it stops. We're trying the relay/board advice given to Lisa.
    Thanks.
    Genius:
  • 1,028 Answers
Pull end caps off just grab at top of plastic and pull towards you remove the 2 screws underneath lift console up and roll back next to timer is a small control bd to right of that are 2 relays 1 with red wires for element and 1 with blue wires for motor first try switching the relays they are identical and will work for either 1 ..try if works replace relay ..if still not working suspect control bd
Posted on Jul 01, 2008
I have a similar problem with my Kenmore P/N # 3391522. I start the unit and about 5 seconds after it shuts off. I can keep pressing the button each time it stops but after 4 times the dryer will not come back on for a few minutes. I have taken the motor out and started checking for continuity on wire to make sure none were broken. Can someone please help?
Thanks
Richard
Posted on Dec 26, 2008
Tdc30 start switch doesnt stay
It is the door switch that is the problem.
Nov 07, 2012 | Dryers
Kitchenaid prestige dryer will not tumble
I fixed one that would not run last Halloween. A Kenmore very similar to a kitchen-aid dryer:
4 Wheel dryer DE-mystatified
Jul 08, 2012 | Dryers
Won't tumble. Drum won't roll. How do we open it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
Dryer will not stay on
That sounds like the motor is bad.
Dec 28, 2009 | Kenmore 800 7982 Dryer
My Kenmore dryer 78942892 won't tumble when I press the start button. It begins makes a noise but doesn't tumble, then it just turns off.
sounds like the motor . remove drum and try to turn shaft . i think you will fint it won't . replace motor .. m m
Dec 24, 2009 | Kenmore 63942 Dryer
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Kenmore 63952 Electric Dryer Logo
265 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
