Question about NetGear WGR614 Wireless Router
Wireless have a new netgear n wireless router. still have some weak signal in the house for a MAC. How can I boost the signal?
    Scholar:
  • 77 Answers
There are several ways to boost the signal from your router. One, you could try moving it to a central location of the house..the more walls and obstacles, the worse the signal. Try moving any cordless phones away from due to the wireless phones transmitting on the same frequency causing interference. You could also purchase a repeater from an electronics store..I believe AirLink makes one. These devices intercept the original signal and act as a booster..you would try to center this device in your home as well. You could also purchase a better antenna for your router with a higher gain output. Just some suggestions.
Good Luck
Posted on Jul 01, 2008
What kind of wireless access point or extender should I use to project wifi in far bedrooms of a long, train-car like house?
Hi James, the wireless extender is the best way but you should go for the plug in type.....this plugs into the mains and gives you wifi and 1 wired connection, so you can plug into the room you want wifi to reach, I have linked a Netgear option but there are others! EX2700
Jan 18, 2015 | NetGear Computers & Internet
What kind of wireless access point or extender should I use to project wifi in far bedrooms of a long, narrow house?
Yes. You are right on track with hard wiring the extender unit. You can also daisy chain another router to that at a distance that is closer to the furthest room. This will give you plenty of signal through out your house.
I want to boost my wireless signal with an old router
Here is 10 tips to boost your router signal...
http://www.microsoft.com/athome/setup/wirelesstips.aspx#fbid=_0qicF8Ecmt
Feb 06, 2013 | Computers & Internet
Netgear dgn1000 modem router keeps dropping out
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 29, 2012 | NetGear Computers & Internet
The signal from my router to my Samsung blu ray is not strong enough
There are several things you need to consider with wireless connection:
Distance - How far is the Netgear router from the Samsung Blu ray? Try changing the wireless channel on the Netgear router that can help boost the signal. Wireless Security- Have you enabled wireless security on the router? Is it WEP or WPA? Make sure that you input the wireless security key on the Blu Ray player and that you have setup wireless settings correctly.Number of wireless devices - Check the number of wireless devices(laptops, desktops, pda's, etc) connecting to the router as it also weakens the signal. And if wireless security is not enabled on your Netgear router, there's a chance that your neighbor might be connecting to your router via wireless.
You can also test how strong the signal is by placing a wireless laptop on the same location where the blu ray player is. If the laptop gets a weak signal as well, you can try placing the router closer to the blu ray player.
Oct 24, 2011 | NetGear WNR2000 Wireless Router
Poor signal range - I have just moved to a new three storey house. My router is installed at the front of the house on the main/mid floor. I receive a very weak signal on my laptop in my kitty corner...
The general rule for WiFi is to have the router placed at a reasonable height above the items that wish to use it. This is because the radio waves travel downwards
It was probably a repeater that was recommended to boost the signal.
Sep 16, 2017 | Linksys WRT160N Wireless Router
My laptop is in the living room, my 2WIRE router in the bedroom. When I turn on the MAC it sometimes indicates that I am not connected to the Internet. I then have to fool around with diagnostics to try...
I would boost the signal it can only help I had the same sort of problems but my wireless router quit working properly my iPad wouldn't pick up signal so I had to replace my wireless router hope this helps Merry Christmas
Dec 09, 2017 | 2wire Wireless-G 802.11g ADSL Gateway
My router routes to my laptop within my house and
The possible cause is the router is not able to extend the signal to that range. Try using a range extender to boost your wireless signal. Signal strength depends on the router. So adding a range extender should solve this issue
Jan 16, 2010 | Linksys Wireless-G Broadband Router
I got a new router (Netgear W..8.)for my home
try puuting the wireless access point on the middle and atleast 5 ft of the ground this will increase your signal slightly also make sure that there is no cordless phone especially the base near the wireless access point.
Sep 15, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
Netgear WPN 824 Low wireless signal
If you can access the router setup page, the best way to boost the signal is to change the wireless channel on the router setup page to a higher channel so the signal will be strong...
May 27, 2009 | NetGear RangeMax WPN824 Router
NetGear WGR614 Wireless Router Logo
233 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
