Question about Microsoft Xbox 360 Console
Disc wont play
Hey my xbox 360 wont play my discs every time i turn my xbox on instead of saying what game is in it all it says is there is a DVD in it when there actually is a game in it and every time i try to start the game it sounds like it is loading the game but then a white screen pops up and it says "to play this disc put it in an xbox 360 console" it has been doing this for about a month now and i have had the 360 for just about a year and a half
  • dafunksta Nov 20, 2008
    hey my xbox 360 wont play my discs every time i turn my xbox on instead of saying what game is in it all it says is there is a DVD in it when there actually is a game in it and every time i try to start the game it sounds like it is loading the game but then a white screen pops up and it says "to play this disc put it in an xbox 360 console" it has been doing this for about a month now and i have had the 360 for just about a year and a half
  • 3 Answers
This is an intermittent fault for me. I am going to open mine up and put a new drive in, that may well fix it. I think it's due to laser-tracking. As mine will some times make a beefier 'powering-up' noise and start a game fine, but only after I eject and close the drive several times. It's worse on slightly scratched discs which would lead me to belief that it's the drive.
Posted on Jul 01, 2008
I have the same prob my solution get a sony
Wht does it mean when you put a xbox 360 gme in the console and it says play dvd and sometimesa wont read the game discs
When it says play dvd, it just randomly doesn't recognize that it's a game. Press A and you'll enter the game.
When it doesn't recognize the disc all together, I'd suggest cleaning the disc with an anti-static cloth then putting the disc back in.
Mar 05, 2011 | Microsoft Xbox 360 Console
When we put in a game for our 360 system it says it's playing a dvd we can't get the game to work. how do i fix it so it says play game amd not play dvd? (it only does this with 1 game. the rest work fine
Ok if your for certain thats the original dvd drive and the other games work then its too many scratches on the disc or your laser lens needs wiped off with qtip and rubbing alcohol.
If you get an xbox thats say play dvd all the time on every game and it says to play this disc stick in a xbox 360 console then its the wrong dvd drive for that motherboard and you wont get the key (on a chip in the motherboard on the cd drive) unless you have the original dvd drive taken out of your xbox. Then you can just switch that little motherboard on the bottom of the dvd drives and it will read games. This is for those who will look at this with a xbox off ebay that they cant figure out how to fix. Its just an expensive dvd player.
Dec 26, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
Game wont read says put disc in xbox 360 but i am using xbox 360 also it says its a dvd not game just wont let me play no more
If you have recently tried to mod your Xbox 360 then you did not get the drive key installed correctly. Otherwise the laser lens is either dirty/ starting to weaken. You can either replace the laser lens in the disc drive, try to clean it, try the POT tweak or replace the whole disc drive. Keep in mind if you replace the disc drive you will need to swap the PCBs or the drive keys. Hope this helps.
GATpro
May 21, 2010 | Microsoft Fable 2 for Xbox 360
Fable 2 for Xbox 360: game wont read says put disc in xbox 360 but i am ...
One. Make sure the bar code on the band on the inner ring is perfectley clean and dusted. Two blow into the disc drive to make sure there is no dust on the laser. Three, get a professional to look at it such as a person at Game or at Gamestation. Four, try replacing the copy (NOT RECOMMENDED YOU COULD WASTE MONEY)
May 18, 2010 | Microsoft Fable 2 for Xbox 360
My xbox360 wont play some xbox360 games it says put in 360 console well it is a 360 console. What so i do?
you do it is very simple , you can manually fix your problem with the use of repair guide,, it is a complete version to fix your problems caused by xbox.
if you want to download click here.
May 14, 2010 | Microsoft Xbox 360 Console
Xbox 360 wont play games
If your Xbox 360 will not read your games this is because of the sensors on the back of the drive taking too much heat.
You need to send it in to get it fixed or you can fix it yourself using a good guide
Feb 05, 2010 | Microsoft Xbox 360 Console
Wont read disc,instead says open tray
Try turning the xbox on and off. Try removing the power from the xbox and plugging it back in. Try other discs and see if it works. Try doing updates on your xbox360 and see if that fixes the problem. That fixed mine with Halo.
Aug 07, 2009 | Microsoft Xbox 360 Pro System Console
Same problem
If you have a flashed Xbox 360 it could be that the new game has a protection called Wave3.
That protection makes the games to run as a DVD if the speed of the dvd is not 12X.
Because when you got a flashed DVD, your dvd doesn´t play games and dvds at 12X speed.
That makes that wave3 is feeling a higher or lower speed than it should be and blocking it and says Play DVD. Exactly the problem you got.
Jul 27, 2009 | Microsoft Xbox 360 Console
Will not play games
Make sure discs are not scratched. Try cleaning the discs using rubbing alcohol and a soft cloth.
Jan 31, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
139 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
