Question about Dual Presidian DVD Recorder
Presidian PDR 3222 not recording when record button pressed
I have Presidian PDR 3222 DVD recorder. Settalite cable goes to VCR, VCR to DVDR and then to TV. Also AV input three cable to TV input. When I pressed DVD recorder record button, it does not record at all or record light blinks and goes back to play mode. Sometimes putting new disk has helped but 90 % of disk are not recognised or record on it. Why?
  • Scott Frye
    Scott Frye May 11, 2010
    Lite-on makes this thing. LVW-1105HC
    I D/L'ed the firmware update and it wont read it.
I am beginning to think the machine works with slower discs but a firmware update will enable the machine to function with the newer "16x" and other discs. Unfortunately, neither Presidian nor the "real" manufacturer (whose name slipped my mind) seem to currently have the update available on their web sites.
Posted on Sep 28, 2008
How to connect Presidian DVD Recorder Presidian DVD Recorder 3222 directly to TV
I need to know this too, I have a picture but no sound, I've tried every hok up that I can think of
Mar 08, 2013 | Televison & Video
I need a manual for a presidian pdr 3222
Go to the manufacturers website and download the manual.
Mar 26, 2012 | Pinnacle Dazzle DVD Recorder
How do you hook recorder up to tv and dvr cable box
Simple. Connect the composite output from the VCR to the composite input on the back of the Presidian. Then connect the coaxial output from the back of the DVR to the coaxial input on the back of the Presidian. Then connect the coaxial output from Presidian to the coaxial input on the back of the TV. Turn everything on and enjoy! :-)
Jan 05, 2011 | Dual Presidian DVD Recorder
With an old analog tv my presidian pdr 3222 worked great. since moving to a digital tv I have not been able to record using the red record button or set up a timer recording. I'm certainly not an...
so you need a digital\ analog converter , normaly is another SCART connector labed AUX\VCR on receiver box , is analog output. take particular attention on scart cable config. some cables has data transfer pins, and give some strange situations on receivers.
Feb 14, 2010 | Dual Presidian DVD Recorder
Presidian 3222
I don't know if this will help, but according to the operator's manual I have, on page 64, the only place it mentions "Full" or "Quick" Preparation, is when using a DVD-RW disc. Apparently, with this type of disc, you must use the Full or Quick preparation INSTEAD of Finalizing after you're thru recording onto the disc.
With the DVD-R and DVD+R, all you can do is "Finalize"; With the DVD+RW, if I'm reading this correctly, NIETHER Finalization OR Preparation is required.
But with the DVD-RW, apparently ALL you can do is a "FULL" or "QUICK Preparation.
If you're only getting "Erase or "Finalize" WITH the DVD-RW, then it appears there may be a problem with the machine.
Or, if you're attempting the "FULL or QUICK" Preparation with any disc OTHER than the DVD-RW, all you should get is "erase" or Finalize", since the QUICK or FULL Preparation is not done with discs other than DVD-RWs.
Hope this helps. I'm certainly not an expert on these things....I'm a "Vinyl" type guy.
Roy Davis
May 31, 2008 | Dual Presidian DVD Recorder
Recording from cable dvr
You have to hook up an AV cable from the box to the DVDR.. Out on the cable box to IN on the DVD player.
Then put your DVD player on AV1 - ( you can do this by pressing the INPUT SEL button on the DVDR remote)
Then put the Cable box on whatever channel you want to record. And press the record button on the DVDR and you will record whatever channel the cable box is on
If you can't get to AV1 then you have to disable cable box control (menu>setup>system>cable box control>off
Jan 12, 2008 | Samsung DVD-VR357
Presidian dvd recorder pdr 3222
Have had the same problem with my Presidian3222 for the last year, if I recorded something it would come back as invalid disc or blank disc or would not close disc out right, got so damn mad almost took a hammer to it last night, unplugged it like clicky said, did no good, thought cable co may have been sending single to screw up recording, but today took camcorder and tried to record something, same thing which seemed to let the cable co off the hook.
the following seemed to have fixed the problem, first open the player then unplug it, close the drawer 1/2 way, then I took compressed air and blew inside the player to clean the laser after that I have been able to record 3 movies and close the disc properly and finalize the disc properly, I even had 50 new disc made by sony that recorded kept saying were invalid, reads them fine now, I hope this helps everyone, because I was on the edge of putting this thing in the trash last night.
R.J.
Nov 26, 2007 | Dual Presidian DVD Recorder
i have a presidian dvd recorder and when i put in
a new blank dvd-r disc it only gets it prepared up to
21% and tthen it stops and opens
Nov 25, 2007 | Emerson EWD7001 DVD Player
Televison & Video Logo
448 people viewed this question
Top Dual Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Dual Televison and Video Expert? Answer questions, earn points and help others
