Question about Sanyo PLV-Z4 Multimedia Projectors
Sanyo PLC - Z5 Lamp Replacement Light
I've replaced the bulb, but the Lamp Replacement Light still comes on at start-up and the projector shuts down.
  • chr8cm Feb 17, 2009
    Once we reset the overheat switch, it works only until we turn it off & need to use it again. Then we have to go through the whole process of taking it apart...again! Any Advise?
  • 3 Answers
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Posted on Aug 01, 2008
  • johncrabtree
    johncrabtree Feb 14, 2013
    Thanks this helped a lot. Why wouldn't the owners manual have this is beyond me.
We have a Sanyo PLC-XE40 short throw projector that came with Promethean ActivBoard for a classroom. One day it just stopped working, we cleaned the filter replaced the bulb but it wouldnt power up. We called Sanyo and they wanted it shipped to them to reset the overheat switch. I asked them why we couldnt doit ourselves and they said it was a complicated process but if we had more than 20 projectors then they would be able to tell us how to reset it over the phone. So that got me thinking if they can doit over the phone why not crack it open and check it out, and what do you know I found the overheat switch which has been tripped between two motherboards around the lamp area. I reached in there with a small flathead screwdriver and reset the switch. Put everything together and it powered right up. Didnt have to replace a $400 bulb or send it off to Sanyo and not know when we would get it back. So the complicated trick is to take it apart and press a button. I've also asked Sanyo tech support why they cant tell me over the phone how to reset the overheat switch and their answer was they wanted to provide the outmost support care for their products. Go figure.
Posted on Sep 06, 2008
Sanyo Model PLC-xe40 We have had this problem with many of the same model data projectors from Sanyo. The solution is to get Sanyo to sort out the persitent problem with this mode. We have sent back all of our data projectors under warranty. The problem reoccurs. We send the data projectors back. It is a design or engineering problem in my opinion.
Posted on Sep 09, 2009
How do i reset sanyo pro xtrax multiverse projector "replace lamp" error message
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Sanyo PLC-XE20 (Chassis XE2000)...
I have an Sanyo PLC-SU07E Multimedia projector. I
4,select "Yes"
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Aug 09, 2013 | Sanyo PLC SW20A Multimedia Projector
I have a Sanyo PLC XE20 which powers down after a few seconds with a bulb error I purchased a new bulb but the problem persists. What next?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
have a nice day!
Sep 08, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Sanyo XU50 not coming on after lamp replacement
Hi oatesy13
You will have to reset the lamp timer to resolve the problem.
Consult ypour user's manual on how to do this.
Should do the trick , If you do however need any further assistance , please send me a request and I'll respond to it.
May 13, 2008 | Sanyo PLC XU50 Multimedia Projector
PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Aug 11, 2007 | Sanyo PLV Z1 Multimedia Projector
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLV-Z4 Multimedia Projectors Logo
3,035 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
