I have a Canon IR 330 with an error: E677 then it says to power off and power on which I have done to no avail. The error has a little wrench besides it
  • 134 Answers
Error E677 is a problem with the connection between the printer board and the main board of the copier. Most likely the problem is a bad printer board, assuming no one has opened the back cover of the copier and the unit was working recently.
Posted on Jul 01, 2008
My xerox machine IR 400 gets an error e677
http://www.fixya.com/postanswer.aspx?thid=8792841&prdid=189719&ctgid=169&ref=unslt
Mar 31, 2011 | Canon imageRUNNER 400S Copier
Errors codes E677 & E005 trying to find a total usage counter for all copies done on the machine
e677 might just be a bad drum. E005 is the cleaning web that needs replaced. The counter is in the upper left side behind the front cover!
Dec 20, 2010 | Canon imageRUNNER 400S Copier
Ihave problem with canon ir 600 .Error show E677
E677 communication error between machine & pc.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Canon imageRUNNER 600 Printer
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
Eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
Jun 01, 2009 | Canon imageRUNNER 400S Copier
E677 Error in canon IR400
switch main power off and on E677
Feb 24, 2009 | Canon imageRUNNER 400S Copier
E677
press the additional * 2+8 additional *
select the copier on the screen
select function
select clear
select ERR
press OK
restart the Copier
Oct 02, 2008 | Canon imageRUNNER 400S Copier
CANON IR 400 COPIER - ERROR - E677
Sep 11, 2008 | Canon imageRUNNER 400S Copier
184 people viewed this question
jasbo
jasbo
