FixYa.com
Tags:
JVC AV-56WP30 56 in. Rear Projection Television
Jvc av56wp30 vertical linearity (by 2 users)
By paulrmc - usenet poster
customers complaint was that people all had "flatheads"...tried
adjusting the service menu adjustments, could correct the flatheads
but then it would be stretched or squeezed somewhere else..caps
checked ok, changed some anyway, no affect...didn't have the vertical
output, have it on order. just wondered if anyone has ran across the
problem with this model..thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by chestos, posted on Jun 15, 2008
not really the same problem the problem i have is the (DVI) port on the back is not working i've change the dvi cable and this is a hdmi to dvi can any one help
Best Solution
posted on Aug 11, 2005
Helpful (85)
Luisa_K
Luisa_K - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
ron:
If you did not "check" the caps with an ESR meter, go back and just replace
all of them in the vertical output circuitry..... near and around the output
chip.   There are about a half dozen of them, so just replace them all...
not that expensive.
Next time, DO NOT adjust the service menu first for this type of fault....
even if it did provide a satisfactory picture, the results would have been
short lived because the capacitors would continue to deteriorate... and if
nursed along for a while longer would eventually cause more expensive damage
and more expensive parts to fail.   replace the faulty parts and usually
there will be no need to get into the service menu.
Best Regards,
Daniel Sofie
Electronics Supply & Repair
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
JVC AV-56WP30 56 in. Rear Projection...
red bar on bottom of screen
Hi i have JVC model#av56wp30... Answer This...
JVC AV-56WP30 56 black screen...
Hello about six months ago my... Answer This...
numbers&letters showing up...
numbers and letters and picture... Answer This...
No picture, clicking sound...
I have a JVC AV-56WP30 56 in.... Answer This...
Picture is off center.
Now that I know which parts to... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
