Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag Dishwasher My model number is: MDB6650AWS - Maytag Jet Clean Dishwasher Plus All the lights on the control panel are flashing and will not stop. I tried to reset but it will not work
  • 3 more comments
  • stbaldini Sep 22, 2008
    Washing and drying cycle finished, light remained on.  Went to shut it off and the wash cycle started again.  How do you turn the dishwasher off?
  • momto4boys Jan 22, 2009
    I cant get the lights to shut off either? How do I reset?
  • drenzer Jan 28, 2009
    Buttons on top of dishwasher work properly, light on front of door displays partial readout; 2n instead of 2H, and dishwasher will not start on cycle start button on front of door
  • jgkenned Feb 28, 2009
    the light over the normal wash cycle just flashes and wont start.
  • Anonymous Mar 20, 2014
    ALL MY PANEL LIGHTS COME ON TO START MY DISHWASHER EXCEPT START BUTTON
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
  • 93 Answers
Replace touch pad and main control board.
Posted on Jul 24, 2008
Maytage dishwasher not running, clean light blinking
the maytag control panels are known to have issues. the problem is they are not sealed properly and over time steam gets in and eventually it shorts. it is fairly easy to change, but you should have it diagnosed by a qualified technician to know for sure. good luck! http://www.searspartsdirect.com/part-number/w10380486/0022/665.html
Oct 04, 2016 | Dishwashers
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
G 2582 scvi
make this test and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
test this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 22, 2013 | Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
I require a manual for a Maytag jet clean dishwasher, super capacity - Quiet Plus, model number mdb4040awa
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Maytag model by clicking the link below.
Maytag MDB4000 User Manual
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 20, 2012 | Dishwashers
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
2,525 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
