Question about Samsung 61" Slim-Depth DLP HDTV
Colored vertical lines through picture The TV was working perfectly. Then i turned it off. Turned it on a half hour later and the entire screen is covered in green vertical lines. Doesn't matter what the source is (DVR, DVD, etc.), lines remain. I've cycled it a few times with no luck. Any suggestions?
    Genius:
  • 1,447 Answers
Hi-
I suspect 2 things, 1 is loose connection on cables and wiring, 2nd is main board- if product is still within warranty call samsung support and have a service tech deal with it- Home service...
Thanks for using fixya, keep us posted!
thanks!
Posted on Jul 01, 2008
    Brigadier General:
  • 3,614 Answers
Well check the resistor on the convergence module, and replace the faulty on you have test...
let me know..
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
TV has a line across the screen when I turn it on.
You have a vertical deflection problem ; probably a shorted vertical output IC.
Mar 30, 2009 | Televison & Video
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
Vertical colored lines on left half of screen.
I had a similar issue. Took it in and apparently i had 4 bad capacitors and after replacing those, my tv was perfect. But I think I lucked out on this one. :) try it.
Nov 02, 2008 | Televison & Video
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical colored lines on top and bottom of screen
Definately a video processing problem and it may need a logic board it is called. Does the set work fine if you feed component into set to bypass all that? Let me know. GURU JAY
Sep 11, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung 61" Slim-Depth DLP HDTV Logo
117 people viewed this question
Henry  Thomas
Henry Thomas
