My pool heater pilot will not stay lite. I can hold down the pilot button and soon as I release it the pilot will go out. Please help!
    Champion:
  • 254 Answers
Ok a couple things to check here would be a thermocouple or a flame switch depending on the the type of ignition source. If it has a standing (continious) pilot you need to look for a small copper line returning from the pilot source to the gas valve most likley this will be it. The other will be a small copper line returning to a switch with 2 wires on the backside this will be a flame switch. the thermocouple could most likley be purchased from your local hardware store but a flame switch will have to come from the heater manufacturer.
Posted on Jul 01, 2008
Laars lite 2 pilot
make sure gas pressure is correct if ok see if the silver tube has a cobweb also make sure all connections are good
Sep 04, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
How to light teledyne laars 1 series pool/spa heater
turn on gas turn to pilot then hold down button light underneath where the small silver tube goes from the gas valve hold down lite then hold for a minute then turn to on should stay lit if not need new pilot generator
Jan 28, 2012 | Teledyne Laars Pool & Spa
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot low when release button, goes out after turn on
Try replacing the pilot generator which is in the pilot assembly. It is the piece with a silver cable coming out of it and that cable splits open into a red and white wire at the gas valve, That piece holds the valve open once it is hot enough and is likely not putting out enough voltage to do its job.
Jun 14, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot lite will not stay lite
You need to change the thermocouple on the unit.
First check to see if the flame is hitting the thermocouple when the flame is on when you hold down the button. If it is then remove the the thermocouple and replace with the same size. You should be able to pick one up at your local hardware store.
If when you replace the thermocouple the flame does not stay lit still you may have a bad gas valve.
Hope this helps and please rate this!
Dec 08, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
