Question about HP DeskJet F380 All-In-One Printer
Installer takes forever
I've been trying to install the HP Deskjet F300 series driver and it's been 5 days already and it's still 94% cmpleted and the install "speed" has gone down to from over 400kbps to 0.7kbps. It didn't take that long to install it in another pc. What's going on?
I'm using Windows XP professional 2002 service pack 2 on an AMD Athlon XP 1.2Ghz, 1GB ram
  • boksbox Jul 01, 2008
    got the installers from HP and driversguide.com and tried both but installer still crawls at 0% on step 3 of 4 after an hour of waiting.
    Novelist:
  • 106 Answers
It seems like your having issue installing the Software of the printer. Here are the things that i want you to follow. Before doing that, make sure that the USB cable that you use to plug-in from the back of the COMPUTER going to the PRINTER is already UNPLUG.
1. Performed level 1, level 2 and level 3 uninstallation, How? follow this.
a.) insert the CD that you used to install the Software.
b.) I want you to open the CD file. (x:\util\ccc), where X is your CD drive.
c.) when the CD file is open, try to loof for UTIL folder and open it, it will give you 2 sub folders, just open the CCC folder.
e.) inside CCC folder, it will give you several files. I want you to run the uninstall_l1.bat file. A black box will open (CMD window) just hit ENTER on your keyboard to start removing the UNSUCCESSFUL INSTALLATION. When the uninstallation is complete, a window will pop-up that will promt you to restart your Computer. DO not restart your computer, instead, click on the box that says "Restart Later". to continue running the next file. (please do not restart your computer after performing the uninstall_l2.
d.) after performing uninstall_l1.bat, run the uninstall_l2, then after that run the uninstall_l3.bat. When uninstall_l3 is done, click on restart on that pop-up box. this time, you need to restart your computer
2. When you computer finish to reboot, try to click on START then go to "RUN". when it opens, type $temp% then click okay.
3. the temporary files will open, delete all the files there.
4. try to reinsert the CD so that the installation box will open.
5. Try to install the Software using the CUSTOM INSTALLATION.
Note: custom installation would let you choose which components of the software that you want to install. AS you go along the installation, it will show you the list of the programs that are going to be installed. I want you to uncheck the following:
1. Customer Participation Program.
2. HPssupply
3. HP update.
4. Photosmart Essential 2.5 (anything that says photosmart)
6. if you already uncheck those, try to click NEXT to continue the installation.
Note: Installing the Printer SOftware would take sometime. Please let me know if the steps i gave to you wont solve the issue so that i can go ahead and give you another best solution..
Thank you so much. And im looking for a positive response from you.
best regards,
adonscott
Posted on Jul 03, 2008
  • 487 Answers
Stop it and get another installer form HP or driversguide.com
this should be done even with a little slower computer in about 30 min at the most
Posted on Jul 01, 2008
HP Deskjet F300
When you click 'print' on your computer, change the printer-settings to "double-sided" or "print on both sides", and then click OK. The printer will do the rest.
Jan 07, 2014 | HP Deskjet F300 series
Hp deskjet f380 disk hp deskjet f300 series will not set up in my toshiba laptop window 7
Try installing your printers windows 7 compatible drivers.You can download the driver by clicking here
and then running the setup.
Hope this helps.Thanks!
Please rate this answer.
Oct 21, 2011 | HP DeskJet F380 All-In-One Printer
I have a HP printer on the front it sayd HP Deskjet F380 but on the back it had f300 all in one series with the model number beingQ8130A. i need a psu for this printer can u help?
HP Deskjet F380 falls under the F300 all in one series of HP Printers.
You need to contact your nearest HP dealer to buy a PSU for your printer. Or else contact HP Technical Support over phone for more info.
Feb 21, 2011 | HP Deskjet F300 series
I have a hp f300 all in one printer and no cd installer for lapto
Use this link, download and burn the software into a disk.
Jul 20, 2009 | HP DeskJet F380 All-In-One Printer
HP deskjet F380
If you are running Win XP or Vista, you may wanna try the steps below:
1. Start > Control Panel
2. Printers and Faxes (for Win XP) - Printers (for Vista)
3. Click the "Add a printer" of the upper left hand corner of your screen.
4. Select Local Printer.
5. Connect your printer to the USB port and turn it ON.
6. Try to detect a Plug-n-Play (PnP) printer
7. If the printer is not detected as a PnP printer, run through the unstallation wizard and select the HP F300 series or F380 > Next
8. Run through the wizard until you finish the installation.
The steps above are the steps for installing the printer driver using the generic printer drivers that are already installed in every Windows computer .
If the generic driver will not work, you may download the driver through this link:
http://www.softwaredriverdownload.com/hp_deskjet_f380_printer_driver.html
Hope it helps and have a great day!
Jun 15, 2009 | HP DeskJet F380 All-In-One Printer
Printer hp deskjet D2360 installer
Click here and select your windows version to download driver
thanks for rating!
Jan 16, 2008 | HP Deskjet D2360 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
335 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
