Question about Sharp SF 2314 Copier
Drum half the page is clear to read, other half is all smeared with black ink and unreadable. how do you change the drum? i've already changed the toner, but can't figure out how to remove old drum to replace new one.
  • 1 more comment
  • d_poore Jul 01, 2008
    So, I don't even change the drum at all? I'm 53 years old and not very mechanically inclined, so can you walk me through my problem starting at the beginning of how to even get to where I need to be to try to resolve this problem.
    it's a sf 2314 copier
    Since my day is almost ended, I will try your solutions tomorrow morning. Can I reach any one @ FixYa tomorrow morning because I'm sure my problem isn't going to fix itself over night. Thanks for your help so far.
  • Sharp Expert
  • 257 Answers
If you replace the drum as you have been told and the problem persists, check for a loose connection around the copy lamp and its circuit and rectify.
Posted on Nov 24, 2009
    Master:
  • 638 Answers
The old drum is connected to the cartridge through a round steel coloured pin from both left and right side you can make the pin little upwards with the help of screw driver and then slightly pull it out with the help of proper tool .
note:do all the opretion in the printer off condition if yo do in printer on condition your new drum will not be excepted and error will occur, and donot remove any wire from the drum unit side connected to the printer with a screw in on condition it will ask for the reset code, that will create more problem.it is hundred percent problem of the drum but if problem presists after changing drum you can also try changing whole drum unit as it is not to costly.if does not get fixed keep me updated as i am having the same toner in front of me at present,so i can guide you more clearly further.
rate the solution as " FIXYA"if helped by this.thanks in advance. wish u success.best of luck. bye
Posted on Jul 01, 2008
    Genius:
  • 1,447 Answers
Hi-
Try cleaning the inside of the printer by removing toners ans using a damp clothe, clean it gently or if you have a device cleaner for the printer try accessing it, then make sure when you install the toner, you install it correctly because for some reason there is something in there in which is blocking the laser light thats why you are getting half the page blank. I dont think that its a problem with the drum since if it requires replacement it should give you an error code or error lights. Best i got.
Thanks or using fixya, update us or keep us posted on the progress that it will make.
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jul 01, 2008
    Yes sure and just check on the forums in the morning for some more suggestions, have a good night then!
  • 1,183 Answers
You can request service manual aswell as service on the following site
http://www.sharpusa.com/products/support/function_support_options/0,2311,36,00.html
Thanks
proton
  • 2 more comments
  • Mandeep  Singh
    Mandeep Singh Jul 01, 2008
    additional help:
    Smudges and dirt can be caused by the following: Original table or original cover is dirty. Clean it regularly. See your manual for details. Original is smudged or blotchy. Use a clean original
  • Mandeep  Singh
    Could you provide with the correct model of the copier, so that we can help you better at fixya
    Thanks
    proton
  • Mandeep  Singh
    Thanks for the information , replacing the drum , would require, special tools.
    If you are not comfortable opening and putting together parts , i would suggest get the expert to do it for you. it would save you time,energy and money.
    You check the closest sharp service centre on the following website. All you have to do is fill in your area code and hit submit
    http://www.sharpusa.com/products/Functio...
  • Mandeep  Singh
    Alternatively you can use a soft dam cloth, and clear the rollers and plates. the same are visible to the eye, when you remove the toner.
    Thanks
    proton
  • 983 Answers
Your drum cartridge should have a little rod that you can carefully pull out and in. This cleans a wire that charges your drum
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 01, 2008
    try cleaning the mirrors do so carefully using an alcohol based cleaning fluid and soft cloths....bounty tissues are usually the best.
    Also you should clean the corona wire that sits in the bottom of the machine. It will look like fishing line. Be gentle
Changed inks, pages are being pinted however very faint in the black areas, changed toner which was still half full but no change in quality of print. coloured areas are excellent with black areas almost...
You must print a lot of black and white documents. The problem is with the black developer in your imaging unit. The problem can be fixed by either replacing your imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. I have a link to describe the problem and how you can clean it using simple household tools. http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Oct 27, 2010 | Samsung CLP 300 Laser Printer
HP laserjet 5000gn when i print, output smears ink on 2 sides. not a toner issue cause changed toners already. someone says printer is telling me something and might be a warning of
If by smearing you mean the print is also rubbing off? Then you definately have a fuser unit issue. The fusing unit is the assembly that heats up and "fuses" the toner onto the page. When these start to go bad, usually on one edge or the other the print will smear/double image/wipe off of the effected area. One test you can do to verify a fuser problem is to print a page and then when the page is about half way thru the prcess, shut the printer off. Open the top and remove the toner cartridge, pull out the page and see if the lower part is not smeared. Basically what your checking is to see if the print is ok BEFORE it goes thru the fuser. Based on your description I would suspect your fuser is going bad.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | HP LaserJet 5000gn Printer
Colored ink is smearing on the page when I print
Did you change the toner?Developer unit? When did it occured?
FIRST: the copier must be cleaned and vacumed, it may be that toner falls onto transfer section and that causes the problem, you may also have problem with yellow developing unit or drum or transfer cleaning blade.
Pls. rate
May 07, 2010 | Canon imageRUNNER iR C4080 Color Copier
My printer worked very well until I changed the toner. I see dust around the back toner. I brought the generic toner. The store manager said that was the problem. Then I brought new HP toner. It is the...
Smeared output can result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
Apr 08, 2010 | HP Hewlett Packard LaserJet 2605dn Printer
Black color has faded to unreadable Have replaced all components
chean the black cartridege with a cleanex and tap it to see if ink will come outm if it does bor then it has dried out and needs replacement.
Jan 11, 2010 | Dell 5100cn Laser Printer
Can smears when priting be fixed
Have you tried cleaning the corona wire on the drum unit (the blue slider bit)?
Replace the drum unit (assuming you have already replaced the toner cart?)
To check the remaining drum life press the go button 3 times. A report should print out with the info on. Even though you may have some remaining life, the drum can fail early.
If the dots/marks are repeating about 3 times down the page it is almost certainly the drum unit that has the problem.
Apr 16, 2009 | Brother HL 5250DN Laser Printer
Printer smears on cold print
The toner cartridge sounds like the problem to me. Did you refill it? Or have it done? It sounds like an incompatible brand......toner is very model specific, and not just 'any' will do, and it often doen't mix well with the remaining toner i the cartridge if it is not completely disassembled and cleaned out. Just curious
Mar 16, 2009 | Brother HL 5250DN Laser Printer
ONE HALF BLACK PAGES WITH SHARP SF-2414
Did you clean the inside of the copier from toner and dirt?
Dec 04, 2008 | Canon NP 6050 Copier
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
Prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Oct 03, 2008 | Lexmark C752 Printer
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
