Question about Everex StepNote NC1500 Notebook
How do I turn my wireless FN button on?
I don't see a light indicating that my wireless communications is turned on!
Hi
This should be easy to fix, On your everex laptop
Look at your keyboard and press the following
FN + F2 They both have blue symbols
You should have your wireless working
Posted on Jul 09, 2008
  • Pradeep Regmi
    Pradeep Regmi Sep 28, 2010
    Thanks a lot it was really nice to get your info.
  • paul treeman
    paul treeman Dec 09, 2016
    There's no fn
How do u find the button to make sure the wireless is on
Hi there!
Depend on the brand of laptops, the position of wireless button is located in different places. Most of the cases, it stays in the front or in the left side of your laptop. It will have the sign or word written to let you know which way to turn on or off the wireless adapter. There is also a wireless light to confirm that the wireless is on or off. And the Fn + Fwireless to turn the wireless adapter on or off too.
So you have : when wireless button is set to Off, whatever you do on laptop still not make the wireless working.
If wireless button is set to On, you still need to press Fn+Fwireless to turn on the wireless.
I don't know you understand or not because it quite messy explaination. I don't know why all laptops have to have 2 places to turn on and off wireless adapter. One place is enough.
Hope this will help.Thanks for reading
Jul 19, 2011 | Computers & Internet
Cant locate wireless button
The Wireless button is at the front of the Laptop. In the following diagram, it is number 6, or Wireless
communication button/indicator:
http://www.4shared.com/document/DHVptXen/Acer_TravelMate_2480_Wireless_.html
Mar 11, 2011 | Acer TravelMate 2480 PC Notebook
How to switch on my wifi
1. There is a wireless on/off switch on the righthand side of the laptop between microphone jack and USB port. Slide this switch to the right to turn it on and to the left to turn it off. Check the Wireless communication indicator on the front side. It will start glowing orange when the wireless communication is enabled.
2. Also, Fn+F8 Key turn on/ off the wireless communication.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 17, 2011 | Toshiba Satellite A60 Notebook
Where is the wireless switch on my laptop? i hold down 'FN' then press 'F8' and i says 'wireless communication is disabled. Please turn on the Wireless communication switch. How do i do this?? thanks
when you press these two keys , alight to indicate wirless is on or off ..
do you see a light come on anywhere on the notebook aropud keyboard or on the sides of the laptop ?
Nov 05, 2010 | Toshiba Computers & Internet
try pressing the Fn + F5 or F6 key. that will enable/disable your wireless adapter.
May 21, 2010 | Computers & Internet
Acer 4720,when switched on wifi button,the light for wifi is flash and the funcion is worked.But switched off wifi button,the light is still on.How can i switch off the light?
For Windows Based Computers
If the drivers for the wireless adapter contain a setting to toggle wireless radio, it can be located using the
following path: Start > Settings > Control Panel > Right click Wireless Network Connection Icon > Properties >
Configure > Advanced tab
Here you will find a textbox with a list of selectable properties that are populated by the device driver. Once you
select a property there will be a value field with a dropdown box containing configuration options that apply to that
specific property. The name of the wireless radio property may vary because the listed properties are dependent on
each specific device driver. It should be fairly intuitive to determine the correct property if you simply have the user
read all the listed properties to you.
Many laptop manufacturers will place a physical switch on the outside casing of the laptop, so that the user can
easily toggle wireless radio. Sometimes these switches get accidentally turned off, or intentionally turned off and the
end user forgets to switch it back. The best practice in these situations is to ask the user to look for a physical switch
on the case of the laptop, possibly with a symbol of a radio tower next to it. After turning the wireless switch on, the
user will probably need to refresh their network list.
Laptops built by certain manufacturers may have a specific keystroke set up to toggle wireless radio.
Below are some examples of wireless radio software and hardware toggles that we have been able to
document:
Acer (General) - FN,F5
ASUS (General) -The F5R has a toggle switch to turn on and off the WIFI; it is located on the left side of the
notebook
Dell (General) - FN,F2 or FN,F8 or FN,F12
Dell d630 (D6xx?) latitude: toggle switch on the left side towards the front by the PCMCIA slots and headphone
jack
E-machine (General) - FN,F2
Fujitsu (General) - FN,F10
HP/Compaq (General Older models) - Button on upper left on keyboard deck
HP/Compaq (General Newer models) - Button on lower left below keyboard
IBM thinkpad (General) - Most have software switch or button on left hand side.
IBM thinkpad (model not further identified) with wireless switch on front edge of case.
Sony Vaio (General) - switch on front left
Toshiba (General) - FN,F5 or FN,F8 or switch
Toshiba Satelite has a physycal switch on front of case. FN+F8 shows wether wireless communications is
enabled or disabled.
For MAC/Apple Based Computers
MAC OS X 10.4.x (Tiger & Earlier)
Open MAc Hard Drive > Applications > Utilities folder > Set the Configure pull-down to Airport.
Make sure the "Airport Power:" says On. (This is the status or your Mac's Airport card.)
If not, click "Turn Airport On" button.
MAC OS X 10.5.x (Leopard)
Click on the: Apple Icon > System Preferences > Network > Airport > Airport Power - On/Off
Jan 20, 2010 | Acer Aspire 4720 Notebook
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
Wireless networking
the key combo is F2 + Fn key (the fn key is located on the bottom row all the to the left) a little blue light lights up that looks like this ((o)) that lets you know it's on. press the combo again to turn of wifi communications.
Nov 15, 2008 | Gateway 7330GZ Notebook
NO WIRELESS CONNECTION
I am aboutsure about the question, but what i understood is wireless switch location
First close your laptop, then look the front view where the speaker is located, From the left
1.Speakers Left and right speakers deliver stereo audio
output.
2 Power indicator Lights up when the computer is on.
3 Battery indicator Lights up when the battery is being charged
4 Bluetooth communication
button/indicator (for
selected models)
Press to enable/disable the Bluetooth
function. Indicates the status of Bluetooth
communication (optional).
5 Wireless communication
button/indicator
Press to enable/disable the wireless function.
Indicates the status of wireless LAN
6 Line-in jack Accepts audio line-in devices (e.g., audio CD
player, stereo walkman).
7 Mic-in jack Accepts inputs from external microphones.
So your wireless switch is the 5th one from the left. Locate it and turn on the wireless, and try to connet to the router.
Try this, hope it may work,
Jan 27, 2008 | Acer Aspire 3000 Notebook
Everex StepNote NC1500 Notebook Logo
2,409 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
