Question about Maytag Washing Machines
The lint is not being washed from machine. All dark clothing has lint residue. How can I rectify this problem please? Currently my husband using damp cloth has to wipe over black clothing extensively prior to ironing. He wants us to replace machine. Our Maytag Performa top loader is approx 3 yrs old and has always had this problem
  • 481 Answers
The self cleaning lint filter seems to be clogged. before you replace it try this cheap/ easy remedy.
  • run a load with no clothes on high water level, hot water and a gallon or two of bleach.
  •  no soap.
  • do an extra rinse after to make sure you rinse all the bleach away before putting more clothes in.
the lint filter may be defective since it has always had this problem, but its worth a try.
Posted on Jul 01, 2008
My washing ,machine doesn't make dark clothes clean and now has a smell coming from it
They make products for this problem, I assume you have a high efficiency front loader.
Jun 22, 2017 | Washing Machines
FWX833AS1
Good Afternoon Friend,
I understand when you wash your dark clothes in your Frigidaire washer, model# FWX833AS1, there is lint left on them after the wash. There are a couple of possibilities that can cause lint.
First, would be incorrect sorting, or possibly tissues left in a pocket. It could be overloading your washer or not using enough detergent. Try reducing your load size. Rewash the clothes using the correct water temperature, water level, and amount of detergent.
Secondly, could be that it is undissolved detergent leaving residue on your clothes. Try adding a nonprecipitating water conditioner to the wash water.
Thirdly, it could be static cling attracting the lint. Try adding fabric softener to the final rinse, if you aren't already.
Lastly, the load could have washed too long.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Washing Machines
Samsung WA422 How do you know if it's not enough water?
The white residue you can see is undissolved soap powder, You need to first try reducing the quantity of powder you are using, there is also a good chance that the machine has built up residue between the inner and outer drum, I'd suggest buying a washing machine cleaner and running it through the machine following the instructions on the packaging, A hot empty wash with a cup of dishwasher powder and once it fills up pausing it to soak for a while will also do the same if you cannot find a washing machine cleaner.
May 14, 2017 | Samsung WA422PRHDWR
My clothes are coming out dirty with lint build up from the washing machine- kelvinator smart drive 053, have undone and cleaned centre- is there a trap underneath anywhere that may be full or blocked?
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature according to soil type. For example, blood and mud are better washed in cold water, while sweat and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for the load can increase linting as there will not be enough detergent to hold the lint in suspension. Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times may not let the detergent dissolve properly. In these cases pre-dissolve the detergent. Overdosing of detergent can also cause residue when foam breaks down and will show as white specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Sep 18, 2013 | Fisher Washing Machines
How do I clean gw711 lint filter
There is no lint filters in these machines,
It is automatically pumped out with the drain water.
9.1 Creasing
cycles have been designed to minimize creasing as they use a lower spin speed. Do not leave wet
9.2 Soiling
than soft water.
9.3
Linting
9.7 Dye Transfer
9.8 Tangling
Jul 09, 2012 | Fisher and Paykel Washing Machines
White residue on black clothing
I am sure you did not wash dark clothes with white, right?
How old is the washing machine?
Do you feel/see any white particles in the basket of the machine, when the cover is open, and it dries out inside?-- when you wipe your hand inside (the dry machine), do you pick up white residue?
What type of soaps are you using?-- any chance they could be causing the residue?
How hard is your water? (Do you have a water softener in the water system?
Please tell us more about your circumstances.
Mack B
Dec 28, 2010 | Washing Machines
Brown marks left on clothing.
You probably have significant lint buildup inside the machine. The lint gets burned by the heater and causes the dark marks on the clothes.
This could indicate a fire hazard!!
The solution is to disassemble the machine and remove all lint residue inside, especially in the heater area.
Apr 19, 2010 | Kenmore 62602 Electric Dryer
My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Jan 25, 2010 | Maytag PAV2300 Top Load Washer
Lint on dark clothes in my Whirlpool Cabrio washing maching
sorry there right ..your not using he or low suddsing detergent ,or your using to much..as the water pumps out of unit the sudds stick to side of tub than when rinse water comes in it washes back on your clothes...i can only give you tips and something to look for...look for water not drainning fast enough ,,cut down on detergent,,wash your dark clothes first..give your unit a bleach clean about a pint of bleach..keep me posted onthejob
Feb 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
574 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
