Toro 42''  Zero Turn Lawn Mower Trailer Package Deal () Logo
j randhawa Posted on Dec 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Needs overhauling - Toro 42'' Zero Turn Lawn Mower Trailer Package Deal ()
Joseph Mueller
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 346 Answers
  • Posted on Apr 05, 2011
Joseph Mueller
Expert
Level 2:
Mentor:
Answers
346
Questions
Helped
171886
Points
784
I recommend a shop like www.arcolawn.com who has parts and all of the updated service notes.
They are a master dealer for Toro and Kohler brands.
Send a message to Tony their Store manager and he can get you what you need.
Make sure to send him your model and serial. tell him Joe sent you.
Joe
1helpful
Why Brake pedal creeps to the floor while holding on a hill?
Yes, that normally does mean air in the system. It sounds like you need a good brake system overhaul, at least new rubbers at each wheel caliper and in the master cylinder. If there has also been water in the system for a while, you may find there is enough corrosion to require replacements instead of overhaul.
1helpful
Repair Audi s3 2002 model 1,8 Quattro
if the cylinder head is the problem just replace it, but the leaking could just be from faulty head gasket you dont need it overhauled, all it needs to be done is take the cylinder head out put new head gasket
1helpful
How much is transmission overhaul? 99 silver ado
That is a question you ask a trans repair shop
Depends on wether you pull it or they do & what needs
to be done
2helpful
24cc craftsman 2 stoke trimmer. took apart everything and cleaned. new fuel lines. cleaned air filter. ran fine saturday. now sunday bogs out while trying to throttle up or just stalls.
Low side adjustment on the carb needs to be opened up or the carb needs to be overhauled. To open up the low sie, find the carb jet adjustment screws. The screw closest to the cylinder is the low side. Turn the screw counter-clockwise 1/2 turn. You may need to romove tho plastic locks from the adjustment screws, or if it is fairly new, you may need to buy a special tool to use on these screws. The tool is available anywhere that sells Poulan parts. If adjusting the screws doesm't fix it, the carb will need to be overhauled or replaced. Check with www.searspartsdirect.com . Replacement carbs are sometimes cheaper than an overhaul.
The carburettor needs an overhaul or replacement.
take carby down to any mower shop ...most brushcutters use same carbys...
My rolex daytona is gaining 2 min over-night
Your watch needs overhaul (means service ). When the time goes by, the oil used for reducing friction is reverting itself to the slimy residue, so, starting to slow/speed the watch up. Every watch, no matter what make it is, needs a proper overhaul every 2-5 years (depends on watch movement).
Jan 21, 2010 • Watches
Blow by
If the nailer is leaking out the trigger, it has to be replaced. If it is coming out of the exhaust then it needs an overhaul kit.
Parts are as follows
Trigger valve P/N TVA 11
Overhaul Kit ORK 11
Hope this helps
Tag heuer carrera - does not work timely !!!
There is no reason to panic. Your watch needs overhaul. Find your nearest watch repairer and ask to do the job. He will be able to tell you if there are any mechanical faults.
I do not think there are any and your watch will tick as brand new after overhauling it.
Mechanical watches needs overhaul every 5-7 years.
Filter Queen Majestic Repair Service Essex United Kingdom
when you mean overhaul is the motor not working or are you experiencing loss of suction or wha seems to be the problem?
2answers
I need engine parts for overhaul of 1998 nissan serena 2.5 liter direct injection turbo diesel engine
Hi again,
Is your Serena:
1. auto transmission or conventional shift?
2. 4 wheel drive or Front Drive?
Salamat ulit.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
